for controlling connection parameters
Hi. I'm using nRF52832, SDK13, S312v4 as peripheral.
I want to change connection parameter as below.
#define MIN_CONN_INTERVAL_FAST MSEC_TO_UNITS(30, UNIT_1_25_MS) #define MAX_CONN_INTERVAL_FAST MSEC_TO_UNITS(60, UNIT_1_25_MS)
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(100, UNIT_1_25_MS) #define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS)
static void gap_connection_interval(unsigned short conn_handle_val, unsigned char interval) {
ret_code_t              err_code;
if(interval==CON_INTERVAL_FAST)
	gap_conn_params.min_conn_interval = MIN_CONN_INTERVAL_FAST;
	gap_conn_params.max_conn_interval = MAX_CONN_INTERVAL_FAST;
	gap_conn_params.slave_latency	  = SLAVE_LATENCY;
err_code = sd_ble_gap_conn_param_update(conn_handle_val, &gap_conn_params);
static void gap_params_init(void) {
                                      (const uint8_t *)DEVICE_NAME,
                                      strlen(DEVICE_NAME));
err_code = sd_ble_gap_tx_power_set(TX_POWER_LEVEL);
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(20000) #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) #define MAX_CONN_PARAMS_UPDATE_COUNT 3
static void conn_params_init(void) {
cp_init.disconnect_on_fail             = true;
step 1. gap_params_init() : slow interval. after connection, it works well.
step 2. gap_connection_interval(conn_handle_val, CON_INTERVAL_FAST) : fast interval, it works well.
step 3. gap_connection_interval(conn_handle_val, CON_INTERVAL_SLOW) : slow interval, it works well.
step 4. gap_connection_interval(conn_handle_val, CON_INTERVAL_FAST) : fast interval again, it doesn't work. and system goes stop.
Why does it work just 2 times? I have to change connection interval many times. Do I have to change "conn_params_init()"? How can I do that?
I need your help.
