System crash when both use softdevie and spi
Dear all,
My chip is nrf52832, and sdk version is SDK12.1.0_0d232a. And tried to use ble service and spi master function.
I create a timer to send spi command every 4 ms.
void spi_master_init(void) {
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin           = SPI_SS_PIN;
spi_config.miso_pin         = SPI_MISO_PIN;
spi_config.mosi_pin         = SPI_MOSI_PIN;
spi_config.sck_pin          = SPI_SCK_PIN;
spi_config.frequency        = NRF_DRV_SPI_FREQ_8M;
spi_config.irq_priority     = 6;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
static void spi_send_handler(void * p_context) {
if(spi_xfer_done) {
    memset(spi_rx_buf, 0, spi_length);
    nrf_drv_spi_transfer(&spi, data_tmp, spi_length, spi_rx_buf, spi_length);
    spi_xfer_done = false;
void spi_event_handler(nrf_drv_spi_evt_t const * p_event) {
if (spi_rx_buf[0] != 0)
	command and request data
spi_xfer_done = true;
int main(void) { bool erase_bonds;
APP_ERROR_CHECK( NRF_LOG_INIT(NULL));
timers_init();
nrf_delay_ms(3000);
if (erase_bonds)
    NRF_LOG_INFO("Bonds erased!\r\n");
ble_stack_init();
peer_manager_init(erase_bonds);
db_discovery_init();
spi_master_init();
hrs_c_init();
application_timers_start();
gap_params_init();
conn_params_init();
services_init();
advertising_init();
adv_scan_start();
for (;;)
        // Wait for BLE events.
        power_manage();
After some times, the system will crash.
If I request long data or send command faster. The number of occurrences will increased. It look like the spi handler was Interrupted by softdevice.
And I try to use high priority or low frequence, it still not use.
It will stopped at hardfault.
Any suggestions or pointers are very much appreciated.
Thanks!!!!
  • FormerMember
    0 FormerMember
    At which location does your application hardfault?
    Do you have tried to search the forum for a similar case?
  • Hi Kristin,
    I print message and it always stoped after timer or spi handler. If I use debug mode step by step trace, it always happened fatal error.
    I have searched, but I didn't see the same similar case. No one use timer to do long data transfer(200 bytes) and use both spi master and softdevice
    Thanks!!
  • FormerMember
    0 FormerMember
    If you run the chip in debug mode, and set a breakpoint in the hardfault handler which location does the hardfault originates from? (When doing this, do not single step, but make the application run until it hits the hardfault.)
  • Hi Kristin,
    I don't know how to see the hardfault originates from. I set break point at HardFault_Handler, i don't see any other message. Is there any example or method?
    I have tried debug, and it occurred at a strange place.
    I called a function in timer, i can see the debug print in timer. But i don't see the debug print in called function.
    the code as follow:
    In timer:
    NRF_LOG_INFO("Send spi data\r\n");
    send_spi_command(type, command, data, 128);
    static uint8_t send_spi_command(uint8_t type, uint8_t command, uint8_t* data, uint8_t length) { NRF_LOG_INFO("Command : %d(%d)\r\n", command, spi_send_buf);
    memset(data_tmp[spi_send_buf - 1], 0xFF, 256);
    data_tmp[spi_send_buf - 1][0] = spi_send_buf;
    data_tmp[spi_send_buf - 1][1] = type;
    data_tmp[spi_send_buf - 1][2] = command;
    if (data != NULL) {
        memcpy(&data_tmp[spi_send_buf - 1][3], data, length);
    spi_send_counter++;
    return 0;
    static void spi_schedule_handler(void * p_context)
    if(spi_send_counter && spi_xfer_done) {
        nrf_drv_spi_transfer(&spi, data_tmp[spi_send_buf_count - 1], spi_length, spi_rx_buf, spi_length);
        spi_send_counter--;
        goto end;
    I call the function (send_spi_command) to send data, and i print message before and after the command. It only print the first message.
    And it did't print NRF_LOG_INFO("Command : %d(%d)\r\n", command, spi_send_buf);
    Thanks!!!
  • FormerMember
    0 FormerMember
    This app note from Keil, section "Debugging Faults with uVision" can be useful for determining where the hardfault occurs.
1 2
