What does it mean when debugger head lands on 0x00000000?
I'm running on a nrf51822 chip, using Keil and a JLink Segger programmer. I'm running on SDK 12.2.0 and I believe I was correct in choosing pca 10028 s130 but I'm not 100% sure. I had to modify the target device when I started with the ble_app_template.
When I am running the debugger, It will go through the power manager loop 1 or 2 times, reset to be beginning, repeat a few times, and then the execution code jumps to 0x00000000 and loops there forever. If I operate outside debugger mode, it just loops 1-6 times and then resets (I know because I am advertising a loop count as part of some ble beacon information).
  • Ok, I have been going through some more research on the settings that this chip requires and what the soft device requires. Since it is the s130, I looked at the infocenter pdf for the softdevice specification, made sure that the ram and rom memory locations in the project options matched correctly on the starting locations, then I made sure that the ram didn't exceed what the nrf51822qfaa indicated it had which was 16kB of ram. Since the softdevice was using 5kb of ram, I set the application to use 10 kb of ram so the size is at 0x2800 and then I set the crystal to 16MHz according to the spec sheet from the company in china, and now when I run it, it actually landed on the app_error_handler function with the line number error code and file name information. Yay!
