being discovered service using milti-link peripheral
Hi. i'm using nRF52832, SDK13, S132v4 as multi-link peripheral.
As I know, SDK13 supports multi-link peripheral refering to example "experimental_ble_app_multiperipheral".
But as I tested, when 1 central is connected, other centrals can make connections but can't discover services.
What could be the problem?
here is source code for this case. it is example source code.
static void services_init(void) {
err_code = ble_lbs_init(&m_lbs, &init); APP_ERROR_CHECK(err_code);
uint32_t ble_lbs_init(ble_lbs_t * p_lbs, const ble_lbs_init_t * p_lbs_init) {
// Add characteristics.
err_code = button_char_add(p_lbs, p_lbs_init); VERIFY_SUCCESS(err_code); ......
static uint32_t button_char_add(ble_lbs_t * p_lbs, const ble_lbs_init_t * p_lbs_init) {
return sd_ble_gatts_characteristic_add(p_lbs->service_handle, &char_md, &attr_char_value, &p_lbs->button_char_handles);
I hope your reply.
    It should not be necessary to change anything in nrf_ble_gatt.h. The peripheral link count is defined in main.c as #define PERIPHERAL_LINK_COUNT 4 (line 69). I just tested the example by connecting 2 centrals, and it worked fine.
