I've been debugging my code and would like to use the Memory Watch Unit (MWU). I use SDK version 11, s132, and NRF52.
Could you point to an example of using MWU with SoftDevice enabled? Or any kind of example as I've not been able to find any... with or without the SD.
I've tried to use the NRF_MWU->REGION members 0 and 1, but I get an application fault 0x1001. Is there somewhere in the documentation that the SD is using these? Or is this something else?
If I use the regions 2 and 3, I get an application fault 1. I added the following to my main function, but it did not help.
uint32_t result = sd_softdevice_vector_table_base_set( ApplicationAddress );
APP_ERROR_CHECK( result );
sd_nvic_SetPriority( MWU_IRQn, APP_IRQ_PRIORITY_THREAD );
sd_nvic_ClearPendingIRQ( MWU_IRQn );
sd_nvic_EnableIRQ( MWU_IRQn );
To start the memory watching:
NRF_MWU->REGION[2].START = (uint32_t) <start address>
NRF_MWU->REGION[2].END = (uint32_t) <end address>
NRF_MWU->INTENSET = MWU_INTENSET_REGION2WA_Enabled << MWU_INTENSET_REGION2WA_Pos;
NRF_MWU->REGIONENSET = MWU_REGIONENSET_RGN2WA_Enabled << MWU_REGIONENSET_RGN2WA_Pos;
And I have an IRQ handler function:
void MWU_IRQHandler( void )
.. code ...
Ideas would be appreciated,
Kai
