/* TWI instance. */
static const nrf_drv_twi_t LTC2499P1 = NRF_DRV_TWI_INSTANCE(0);
static const nrf_drv_twi_t LTC2499P2 = NRF_DRV_TWI_INSTANCE(1);
static void LTC2499P1_Handler(nrf_drv_twi_evt_t const * p_event, void * p_context){
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
else if(p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX)
static void LTC2499P2_Handler(nrf_drv_twi_evt_t const * p_event, void * p_context){
static void twi_config(void)
ret_code_t err_code;
const nrf_drv_twi_config_t config1 = {
.scl = LTC2499_DEV2_SCL_PIN,
.sda = LTC2499_DEV2_SDA_PIN,
.frequency = NRF_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
.clear_bus_init = true
const nrf_drv_twi_config_t config2 = {
.scl = LTC2499_DEV1_SCL_PIN,
.sda = LTC2499_DEV1_SDA_PIN,
err_code = nrf_drv_twi_init(<C2499P1, &config1, LTC2499P1_Handler, NULL);
nrf_drv_twi_enable(<C2499P1);
err_code = nrf_drv_twi_init(<C2499P2, &config2, LTC2499P2_Handler, NULL);
nrf_drv_twi_enable(<C2499P2);
ret_code_t LTC2499_init(void){
ret_code_t ret = NRF_SUCCESS;
const uint8_t config[2] = {
(0x80 | _BV(LTC2499_CONFIG1_ENABLE) | (0x1F & LTC2499_CONFIG2_60_50HZ_REJ)),
(_BV(LTC2499_CONFIG2_ENABLE2) | (0x7f & LTC2499_CONFIG2_60_50HZ_REJ))
twi_config();
ret = nrf_drv_twi_tx(<C2499P1,LTC2499_ADDRESS,config,2,false);
if(ret != NRF_SUCCESS)
return ret;
ret = nrf_drv_twi_tx(<C2499P2,LTC2499_ADDRESS,config,2,false);
return ret;
return NRF_SUCCESS;
i wanna use two twi master. but Only one twi runs.I hope for help.
