How to change SDK_13.0.0.4 projects in order to use s140_nrf52840_5.0.0-3.alpha
I'm using SDK nRF5_SDK_13.0.0_04a0bfd and compiling the example ble_peripheral/ble_app_hrs/pca10056/s140/armgcc using Eclipse Mars 2.
Flashing softdevice s140_nrf52840_5.0.0-2.alpha supplied with the SDK and then loading the compiled app works fine (light blinking and device advertising), but I need to use the new s140_nrf52840_5.0.0-3.alpha softdevice in order to test the long range functionality.
I have updated my linker script memory locations in the project from the original:
FLASH (rx) : ORIGIN = 0x22000, LENGTH = 0xde000
RAM (rwx) : ORIGIN = 0x20002620, LENGTH = 0x3d9e0
to:
FLASH (rx) : ORIGIN = 0x24000, LENGTH = 0xdc000
I left the RAM the same since the release notes did not indicate an increase in RAM requirement.
After I flash the new softdevice using nRFGo Studio, and then the app, the app wont start up.
What else do I need to change to make this example work with the latest -3.alpha softdevice?
    The S140 5.0.0-3.alpha adds support for connecting directly on Long Range / LE Coded PHY, while with 5.0.0-2.alpha the initial connection was established with regular 1Mbps mode.
    You can find a migration document,s140_nrf52840_5.0.0-3.alpha_migration-document, attached with s140_nrf52840_5.0.0-3.alpha that describes how to migrate to S140 5.0.0-3.alpha.
    One of the first thing you need to do is to copy the header files found in s140_nrf52840_5.0.0-3.alpha_API\include to your SDK folder SDK_folder\components\softdevice\s140\headers. After that you need to apply the changes described in the migration document. You can also find a patch, sdk_diff.patch, in the ble_app_att_mtu_throughput_example_connecting_on_long_range folder, that shows you the changes needed in e.g. ble_advdata.c
