How do I transfer a large file w/L2CAP oriented connection and credit based flow control?
I'm looking for a way to transfer a large file at high transfer rate with an L2CAP oriented connection with credit based flow control, as briefly referenced in this post.
devzone.nordicsemi.com/.../what-is-credit-based-flow-control-l2cap-channel
If you want more detail I suggest you examine Vol. 3, Part A Section 3.4, 4.22, 4.23, 4.24 and 10.1 in the Bluetooth Core Specification 4.2.
I'm using a nrf52832, with an s132 soft device, and operating in peripheral mode.
I can't find a way to do this through the API. I've seen some other questions, as well as some good write-ups by Ulrich on the matter, but nothing that allows me to take control directly.
devzone.nordicsemi.com/.../ devzone.nordicsemi.com/.../
The CC2640 (www.ti.com/.../CC2640) has a function that lets the programmer set the credits...
www.ti.com/.../swru393d.pdf
bStatus_t L2CAP_FlowCtrlCredit( uint16 CID, uint16 peerCredits )
The s132 l2cap allows me to un/register a cid, and send data, but I can't find where to set credits. It seems like this device does/should support what I'm trying to do.
This may just be a case of me looking too hard. Does it do this by itself/controlled by the master? Or is there even a higher level call I can use to get this functionality without losing too much control...
What am I missing?
Thanks in advance.
  • Connection-oriented channels in LE credit based flow control mode is currently not supported by any of our ordinary SoftDevices.
    It it is supported by a prototype SoftDevice that is used with the IoT SDK.
    If you want more information on if and when we will support this you should contact the regional sales manager for your area. If you don't know who it is, send me a PM with your location and I'll let you know.
