nRF52 SDK12.2 fails SOFTDEVICE_HANDLER_INIT when debugging
Trying to get the debugger working with Eclipse on SDK 12.2 using the nrf52832. Using the ble_app_hrs example, I can flash the application and the "Nordic HRM" device shows up on my phone. However if I try to debug the application, I end up in the app_error_handler because SOFTDEVICE_HANDLER_INIT supposedly returned an error code 8.
Note to make sure the debug action was loading the correct code, I erased the device then used the debug to program it. It failed with usual error code 8, I stopped the debugger, reset the board and the "Nordic HRM" device appeared and worked as usual.
How can this program work when run without debugger but continuously fail here when debugging?
