pstorage request block id
Currently I'm working on updating some code based op pstorage on the nRF51822 with SDK 10 an SD S110 (v8).
Right know we're not using "blocks". We're using pstorage_update(&m_pstorage_handle, ...) directly on the handle obtained via pstorage_register(&param, &m_pstorage_handle). Which causes all data to be saved in the address 0x3B800 to 0x3B810. Our bootloader starts at 0x3C000. Yet all documentation point to the fact that you need to use block via pstorage_block_identifier_get(). We only use one block, but I would want the code to be future proof (we support OTA update) so it's probably a good idea to do so.
So does the number of blocks include the swap block? Or can I just use pstorage_block_identifier_get(&m_pstorage_handle, 0, &block_handle);? Our params look like this:
pstorage_module_param_t param;
param.block_size  = 0x40;
param.block_count = 0x01;
param.cb          = pstorage_callback;
edit: also we would like to preserve data during DFU that's why I'm checking the addresses
Thanks!
