Moving project from Keil to Eclipse : Make fails
Hey there!
I am trying to switch from Keil to Eclipse.
I have followed several tutorials on this website (like this one) and I can easily create new eclipse project, import SDK examples, then build, flash & debug...
That was easy because "examples" are provided with a gcc section that contains a makefile.
So, I have rewritten a new makefile based on example makefiles, like this question.
All seems to work until the linking:
"C:\Program Files\GNU ARM Eclipse\Build Tools\2.8-201611221915\bin\make.exe"
rm -rf _build
echo  Makefile
 Makefile
mkdir _build
Compiling file: ble_common.c
Compiling file: app_fifo.c
Compiling file: fds.c
Compiling file: fstorage.c
Compiling file: nrf_assert.c
Compiling file: sdk_mapped_flags.c
Compiling file: softdevice_handler.c
Assembly file: gcc_startup_nrf51.s
Linking target: nrf51422_xxac_s130.out
_build/gcc_startup_nrf51.o: In function `Reset_Handler':
(.text+0x34): undefined reference to `SystemInit'
(.text+0x38): undefined reference to `__START'
collect2.exe: error: ld returned 1 exit status
Makefile:224: recipe for target 'nrf51422_xxac_s130' failed
make: *** [nrf51422_xxac_s130] Error 1
I do not clearly understand what is happening because it is a file provided in the SDK... I have not modified it. I am using the SDK v12.1.0.
To be sure that the problem was not my SDK, my example makefile or even the builder, I have done the same test on blinky:
C:\Users\***\Desktop\SDK-Test\examples\peripheral\blinky\pca10028\s130\armgcc>
rm -rf _build
echo  Makefile
 Makefile
mkdir _build
Compiling file: system_nrf51.c
Compiling file: main.c
Compiling file: nrf_delay.c
make[1]: Entering directory 'C:/Users/***/Desktop/SDK-Test/examples/peripheral/blinky/pca10028/s130/armgcc'
Preparing: nrf51422_xxac_s130.bin
Preparing: nrf51422_xxac_s130.hex
   text    data     bss     dec     hex filename
   1452     108      28    1588     634 _build/nrf51422_xxac_s130.out
make[1]: Leaving directory 'C:/Users/***/Desktop/SDK-Test/examples/peripheral/blinky/pca10028/s130/armgcc'
On it there is no problem.
Does anyone has an idea of what I have done wrong ?
Thanks for your help!
  • It appears that the SystemInit function is in the system_nrf51.c file. Is this file missing from your Makefile?
    $(SDK_ROOT)/components/toolchain/system_nrf51.c \
    Note that in your blink example, "Compiling file: system_nrf51.c" is shown, is this missing from your main build?
    [Edit] Missed that you were building for nRF51 device.
  • Hey thanks for you answer! That solves partially my problem:
    Makefile:226: recipe for target 'nrf51422_xxac_s130' failed
    I have forgotten to add files that are in "device" (in Keil). The second is "amr_startup_nrf51.s". However, I am getting errors when I try to add it in C_SOURCE_FILES :
    make: *** No rule to make target '_build/arm_startup_nrf51.s', needed by 'nrf51422_xxac_s130'.  Stop.
    Or in ASM_SOURCE_FILES :
    Makefile:245: recipe for target '_build/arm_startup_nrf51.o' failed
    make: *** [_build/arm_startup_nrf51.o] Error 1
  • Hmm I have SDK 12_2 but it doesn't have a seperate ASM files section, they are all under SRC_FILES. My guess is whatever example Makefile you are using is from an older SDK before they changed things.
    What I did was copied the ble_app_hrs Makefile into my project, got it to build. Then added whatever extra source files needed.
  • I have not found what was wrong. However, I have followed your advice and used last SDK 12 release. I have done exactly the same thing for this make file and this time it works! Maybe my SDK was outdated ... Thanks a lot for your help !
