Timer interrupt handler not getting called, please help
I have enabled Timer 2 with 31250Hz frequency. I wanted to call an interrupt after 10ms, ie 312 ticks for the timer. But the interrupt is not getting called, I have spent some time finding the problem, but couldn't find.
Please check the following code, and help me to fix it.
#define UART_TX_BUF_SIZE 256                                                          /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1                                                            /**< UART RX buffer size. */
const nrf_drv_timer_t decode_timeout_timer = NRF_DRV_TIMER_INSTANCE(2); //Time out timer, used to stop decoding
static bool			m_timer_on;
static uint32_t m_tsop_pin;
static uint32_t err_code = NRF_SUCCESS;
static uint16_t m_array_index;
static void decode_timeout_timer_event_handler(nrf_timer_event_t event_type, void * p_context)
	printf("decode timeout event handler got called\n");
    if(event_type == NRF_TIMER_EVENT_COMPARE0)
			printf("TIMEOUT\n");
			nrf_drv_timer_pause(&decode_timeout_timer);
void tsop_pin_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
	printf("\nTimer value is: timer2 %u\n", nrf_drv_timer_capture(&decode_timeout_timer, NRF_TIMER_CC_CHANNEL0));
	if(pin == m_tsop_pin && action == NRF_GPIOTE_POLARITY_TOGGLE )
		if(!m_timer_on)
			printf("Starting decoding...\n");
			m_timer_on = true;
			nrf_drv_timer_enable(&decode_timeout_timer);
static void gpiote_init()
	if(!nrf_drv_gpiote_is_init())
	nrf_drv_gpiote_in_config_t config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
	config.pull = NRF_GPIO_PIN_PULLUP;
	err_code =  nrf_drv_gpiote_in_init(m_tsop_pin, &config, tsop_pin_handler);
	nrf_drv_gpiote_in_event_enable(m_tsop_pin, true);
static void decode_timeout_timer_init()
	nrf_drv_timer_config_t timer_config =  {
        .frequency          = NRF_TIMER_FREQ_31250Hz,
        .mode               = NRF_TIMER_MODE_TIMER,
        .bit_width          = NRF_TIMER_BIT_WIDTH_16,
        .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
        .p_context          = (void *)(uint32_t) decode_timeout_timer.instance_id
	err_code |= nrf_drv_timer_init(&decode_timeout_timer, &timer_config, decode_timeout_timer_event_handler);
	uint32_t time_out_ms = 10;
  uint32_t time_ticks;
	time_ticks = nrf_drv_timer_ms_to_ticks(&decode_timeout_timer, time_out_ms);
	printf("time_ticks: %u", time_ticks);
	//nrf_drv_timer_compare_int_enable(&decode_timeout_timer, NRF_TIMER_CC_CHANNEL0);
  nrf_drv_timer_compare(&decode_timeout_timer, NRF_TIMER_CC_CHANNEL0, time_ticks, true);
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
 * @brief Function for application main entry.
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
         RX_PIN_NUMBER,
         TX_PIN_NUMBER,
         RTS_PIN_NUMBER,
         CTS_PIN_NUMBER,
         APP_UART_FLOW_CONTROL_ENABLED,
         false,
         UART_BAUDRATE_BAUDRATE_Baud38400
                    UART_RX_BUF_SIZE,
                    UART_TX_BUF_SIZE,
                    uart_error_handle,
                    APP_IRQ_PRIORITY_LOW,
                    err_code);
		 m_tsop_pin = 4;
		 decode_timeout_timer_init();
		gpiote_init();
    while (true)
        // Do Nothing - GPIO can be toggled without software intervention.
  • I found the problem. The interrupt is not getting called because, I am also capturing the timer values from the same channel(CC_CHANNEL0). So when I changed the interrupt listen channel to CC_CHANNEL1, everything works fine. I can capture the values from CHANNEL0, and also I can listen for EVENT_COMPARE interrupt at CHANNEL1.
    What I learnt is, don't capture and listen to the same timer channel. Please correct me, if I am wrong.
