sdk 12.2 Migration Peer Manager Bonding/Pairing
I have just migrated my project from sdk 9 to sdk 12.2....and of course from Device Manager to Peer manager. My initial project which was built off of the sdk 9 hrs peripheral example, successfully pairs with IOS and Android, uses whitelists properly etc. Is there a Peer Manager Example that shows how to accomplish this with SDK 12.2?. The apps currently connect fine with no bonding but its not clear to me what modifications I need to make to enable whitelisting and pairing using SDK12. Any working references would be a huge help. Thank you
  • Have you followed this to migrate to Peer Manager? Most examples in the SDK uses Peer Manager. You can have a look at ble_app_hrs for example. For whitelisting you can have a look at ble_app_hids_keyboard.
  • Hello, yes I used the example that you referenced to do the port over to 12.2. I have it all working EXCEPT i cannot connect when I Encrypt the Write Characteristic. This was all working when I was on SDK 9.
    This is the code where I encrypt the characteristics:
    /**@brief Function for adding the get_from_app characteristic.
    static uint32_t get_from_app_char_add(ble_qiqi_t * p_qiqi, const ble_qiqi_init_t * p_qiqi_init)
        ble_gatts_char_md_t char_md;
        ble_gatts_attr_md_t cccd_md;
        ble_gatts_attr_t    attr_char_value;
        ble_uuid_t          ble_uuid;
        ble_gatts_attr_md_t attr_md;
        memset(&cccd_md, 0, sizeof(cccd_md));
    #ifdef CHAR_ENCRYPT
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.read_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&cccd_md.write_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&cccd_md.write_perm); // This works with iPhone 5/5/2016
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
    #else
        cccd_md.vloc = BLE_GATTS_VLOC_STACK;
        memset(&char_md, 0, sizeof(char_md));
        char_md.char_props.read   = 1;
        char_md.char_props.notify = 1;
        char_md.p_char_user_desc  = NULL;
        char_md.p_char_pf         = NULL;
        char_md.p_user_desc_md    = NULL;
        char_md.p_cccd_md         = &cccd_md;
        char_md.p_sccd_md         = NULL;
        ble_uuid.type = p_qiqi->uuid_type;
        ble_uuid.uuid = QIQI_UUID_GET_CHAR;
        memset(&attr_md, 0, sizeof(attr_md));
    #ifdef CHAR_ENCRYPT
        //BLE_GAP_CONN_SEC_MODE_SET_SIGNED_WITH_MITM(&attr_md.read_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(&attr_md.write_perm);  // This works with the iPhone 5/5/2016
        //BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(&attr_md.read_perm);
        BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
        //BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
    #else
        attr_md.vloc       = BLE_GATTS_VLOC_STACK;
        attr_md.rd_auth    = 0;
        attr_md.wr_auth    = 0;
        attr_md.vlen       = 1;
        memset(&attr_char_value, 0, sizeof(attr_char_value));
        attr_char_value.p_uuid       = &ble_uuid;
        attr_char_value.p_attr_md    = &attr_md;
        attr_char_value.init_len     = 20;//sizeof(uint8_t);
        attr_char_value.init_offs    = 0;
        attr_char_value.max_len      = 100;
        attr_char_value.p_value      = NULL;
        return sd_ble_gatts_characteristic_add(p_qiqi->service_handle, &char_md,
                                                   &attr_char_value,
                                                   &p_qiqi->get_from_app_char_handles);
    When CHAR_ENCRYPT is defined the Central (iPhone and Android) breiefly connect, and then the application crashes and restarts. I feel like there is more to do in pm_evt_handler, but not sure what. Here is my pm_evt_handler:
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        switch (p_evt->evt_id)
            case PM_EVT_BONDED_PEER_CONNECTED:
                //NRF_LOG_INFO("Connected to a previously bonded device.\r\n");
            } break;
            case PM_EVT_CONN_SEC_SUCCEEDED:
                NRF_LOG_INFO("Connection secured. Role: %d. conn_handle: %d, Procedure: %d\r\n",
                             ble_conn_state_role(p_evt->conn_handle),
                             p_evt->conn_handle,
                             p_evt->params.conn_sec_succeeded.procedure);
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                /* Often, when securing fails, it shouldn't be restarted, for security reasons.
                 * Other times, it can be restarted directly.
                 * Sometimes it can be restarted, but only after changing some Security Parameters.
                 * Sometimes, it cannot be restarted until the link is disconnected and reconnected.
                 * Sometimes it is impossible, to secure the link, or the peer device does not support it.
                 * How to handle this error is highly application dependent. */
            } break;
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Reject pairing request from an already bonded peer.
                pm_conn_sec_config_t conn_sec_config = {.allow_repairing = false};
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            } break;
            case PM_EVT_STORAGE_FULL:
                // Run garbage collection on the flash.
                err_code = fds_gc();
                if (err_code == FDS_ERR_BUSY || err_code == FDS_ERR_NO_SPACE_IN_QUEUES)
                    // Retry.
            } break;
                advertising_start();
            } break;
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
                // The local database has likely changed, send service changed indications.
                pm_local_database_has_changed();
            } break;
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_data_update_failed.error);
            } break;
            case PM_EVT_PEER_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peer_delete_failed.error);
            } break;
            case PM_EVT_PEERS_DELETE_FAILED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.peers_delete_failed_evt.error);
            } break;
            case PM_EVT_ERROR_UNEXPECTED:
                // Assert.
                APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
            } break;
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
  • Ok. That's unexpected. Would it be possible to share your complete project so I can try to reproduce here? You can share it privately through your MyPage at nordicsemi.com as well. Please include what SoftDevice version you are using as well.
  • Thank you Peter. I have uploaded the Project on MyPage. The Case #: Case ID 35736
    Thank you!
  • Hi Peter, checking to see if you got the files I uploaded onto MyPage. Thank you
