Errors Combining examples twi_sensor and ble_app_uart
I am using SDK 11.0.0 and attempting to integrate the BNO055 IMU into twi_sensor example and then connecting the IMU data over BLE via ble_app_uart.
I successfully integrated the BNO055 IMU into the twi_sensor example by replacing the target accelerometer with the BMO055 IMU. The integration works very well with successful testing collecting accelerometer data from the BNO055 at 200 samples per second over I2C.
I then modified and successfully tested the ble_app_uart example with a transfer interval min of 7.5 mS and max transfer interval of 15 mS.
I am trying to integrate the modified twi_sensor example into the ble_app_uart example and transfer the collected IMU data over ble. I copied the appropriate modified code for the BNO055 IMU version in the twi_sensor example into the ble_app_uart example as a starting point.
However, I am getting the following build issue while doing a make from the command line. I have also included below the makefile modifications to add the source files, cflags, and asmflags to the makefile. I have tried for a couple of days to resolve this issue. I also came across a comment that possibly having different types of interrupt driven peripherals (I2C and UART) may have issues but I do not think the build would be affected by that. Once I get a good build, I can address those issues.
C:\NordicSDK11\examples\ble_peripheral\ble_app_uart\pca10040\s132\armgcc>make
rm -rf _build
echo  Makefile
Makefile
mkdir _build
Compiling file: app_button.c
Compiling file: app_error.c
Compiling file: app_error_weak.c
Compiling file: app_fifo.c
Compiling file: app_timer.c
Compiling file: app_util_platform.c
Compiling file: fstorage.c
Compiling file: nrf_assert.c
Compiling file: nrf_log.c
Compiling file: retarget.c
Compiling file: RTT_Syscalls_GCC.c
Compiling file: SEGGER_RTT.c
Compiling file: SEGGER_RTT_printf.c
Compiling file: app_uart_fifo.c
Compiling file: nrf_delay.c
Compiling file: nrf_drv_common.c
Compiling file: nrf_drv_gpiote.c
Compiling file: nrf_drv_uart.c
Compiling file: pstorage.c
Compiling file: bsp.c
Compiling file: bsp_btn_ble.c
Compiling file: main.c
In file included from C:/NordicSDK11/examples/ble_peripheral/ble_app_uart/main.c:30:0:
C:/NordicSDK11/components/drivers_nrf/twi_master/nrf_drv_twi.h:53:19: error: 'TWI0_USE_EASY_DMA' undeclared here (not in a function)
         (CONCAT_3(TWI, id, _USE_EASY_DMA) == 1 ? \
C:/NordicSDK11/components/libraries/util/nordic_common.h:43:31: note: in definition of macro 'CONCAT_3'
 #define CONCAT_3(p1, p2, p3)  p1##p2##p3
C:/NordicSDK11/components/drivers_nrf/twi_master/nrf_drv_twi.h:88:22: note: in expansion of macro 'NRF_DRV_TWI_PERIPHERAL'
     .reg          = {NRF_DRV_TWI_PERIPHERAL(id)},       \
C:/NordicSDK11/examples/ble_peripheral/ble_app_uart/main.c:131:43: note: in expansion of macro 'NRF_DRV_TWI_INSTANCE'
 static const nrf_drv_twi_t m_twi_bno055 = NRF_DRV_TWI_INSTANCE(0);
C:/NordicSDK11/components/drivers_nrf/twi_master/nrf_drv_twi.h:89:30: error: 'TWI0_INSTANCE_INDEX' undeclared here (not in a function)
     .drv_inst_idx = CONCAT_3(TWI, id, _INSTANCE_INDEX), \
I believe there may be a make file issue with the order of inclusion of source files, cflags, and asmflags. Here is my ble_app_uart make file with the added source and flags from the twi_sensor example.
PROJECT_NAME := ble_app_uart_s132_pca10040
export OUTPUT_FILENAME
#MAKEFILE_NAME := $(CURDIR)/$(word $(words $(MAKEFILE_LIST)),$(MAKEFILE_LIST))
MAKEFILE_NAME := $(MAKEFILE_LIST)
MAKEFILE_DIR := $(dir $(MAKEFILE_NAME) )
TEMPLATE_PATH = ../../../../../../components/toolchain/gcc
ifeq ($(OS),Windows_NT)
include $(TEMPLATE_PATH)/Makefile.windows
include $(TEMPLATE_PATH)/Makefile.posix
endif
MK := mkdir
RM := rm -rf
#echo suspend
ifeq ("$(VERBOSE)","1")
NO_ECHO :=
NO_ECHO := @
endif
# Toolchain commands
CC              := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-gcc'
AS              := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-as'
AR              := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-ar' -r
LD              := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-ld'
NM              := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-nm'
OBJDUMP         := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-objdump'
OBJCOPY         := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-objcopy'
SIZE            := '$(GNU_INSTALL_ROOT)/bin/$(GNU_PREFIX)-size'
#function for removing duplicates in a list
remduplicates = $(strip $(if $1,$(firstword $1) $(call remduplicates,$(filter-out $(firstword $1),$1))))
#source common to all targets
C_SOURCE_FILES += \
$(abspath ../../../../../../components/libraries/button/app_button.c) \
$(abspath ../../../../../../components/libraries/util/app_error.c) \
$(abspath ../../../../../../components/libraries/util/app_error_weak.c) \
$(abspath ../../../../../../components/libraries/fifo/app_fifo.c) \
$(abspath ../../../../../../components/libraries/timer/app_timer.c) \
$(abspath ../../../../../../components/libraries/util/app_util_platform.c) \
$(abspath ../../../../../../components/libraries/fstorage/fstorage.c) \
$(abspath ../../../../../../components/libraries/util/nrf_assert.c) \
$(abspath ../../../../../../components/libraries/util/nrf_log.c) \
$(abspath ../../../../../../components/libraries/uart/retarget.c) \
$(abspath ../../../../../../external/segger_rtt/RTT_Syscalls_GCC.c) \
$(abspath ../../../../../../external/segger_rtt/SEGGER_RTT.c) \
$(abspath ../../../../../../external/segger_rtt/SEGGER_RTT_printf.c) \
$(abspath ../../../../../../components/libraries/uart/app_uart_fifo.c) \
$(abspath ../../../../../../components/drivers_nrf/delay/nrf_delay.c) \
$(abspath ../../../../../../components/drivers_nrf/common/nrf_drv_common.c) \
$(abspath ../../../../../../components/drivers_nrf/gpiote/nrf_drv_gpiote.c) \
$(abspath ../../../../../../components/drivers_nrf/uart/nrf_drv_uart.c) \
$(abspath ../../../../../../components/drivers_nrf/pstorage/pstorage.c) \
$(abspath ../../../../../bsp/bsp.c) \
$(abspath ../../../../../bsp/bsp_btn_ble.c) \
$(abspath ../../../main.c) \
$(abspath ../../../../../../components/ble/common/ble_advdata.c) \
$(abspath ../../../../../../components/ble/ble_advertising/ble_advertising.c) \
$(abspath ../../../../../../components/ble/common/ble_conn_params.c) \
$(abspath ../../../../../../components/ble/ble_services/ble_nus/ble_nus.c) \
$(abspath ../../../../../../components/ble/common/ble_srv_common.c) \
$(abspath ../../../../../../components/toolchain/system_nrf52.c) \
$(abspath ../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c) \
# additional source files from twi_sensor
$(abspath ../../../../../../components/drivers_nrf/twi_master/nrf_drv_twi.c) \
$(abspath ../../../../../../components/drivers_ext/imu_bno055/bno055.c) \
#assembly files common to all targets
ASM_SOURCE_FILES  = $(abspath ../../../../../../components/toolchain/gcc/gcc_startup_nrf52.s)
#includes common to all targets
INC_PATHS  = -I$(abspath ../../../config/ble_app_uart_s132_pca10040)
INC_PATHS += -I$(abspath ../../../config)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/config)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/timer)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/fifo)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/fstorage/config)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/delay)
INC_PATHS += -I$(abspath ../../../../../../components/softdevice/s132/headers/nrf52)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/util)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/uart)
INC_PATHS += -I$(abspath ../../../../../../components/ble/common)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/pstorage)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/uart)
INC_PATHS += -I$(abspath ../../../../../../components/device)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/button)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/fstorage)
INC_PATHS += -I$(abspath ../../../../../../components/libraries/experimental_section_vars)
INC_PATHS += -I$(abspath ../../../../../../components/softdevice/s132/headers)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/gpiote)
INC_PATHS += -I$(abspath ../../../../../../external/segger_rtt)
INC_PATHS += -I$(abspath ../../../../../bsp)
INC_PATHS += -I$(abspath ../../../../../../components/ble/ble_services/ble_nus)
INC_PATHS += -I$(abspath ../../../../../../components/toolchain/CMSIS/Include)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/hal)
INC_PATHS += -I$(abspath ../../../../../../components/toolchain/gcc)
INC_PATHS += -I$(abspath ../../../../../../components/toolchain)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/common)
INC_PATHS += -I$(abspath ../../../../../../components/ble/ble_advertising)
INC_PATHS += -I$(abspath ../../../../../../components/softdevice/common/softdevice_handler)
# additional include paths from twi_sensor example
INC_PATHS += -I$(abspath ../../../../../../components/drivers_nrf/twi_master)
INC_PATHS += -I$(abspath ../../../../../../components/drivers_ext/imu_bno055)
INC_PATHS += -I$(abspath ../../../../../../examples/peripheral/twi_sensor/config/twi_sensor_pca10040)
OBJECT_DIRECTORY = _build
LISTING_DIRECTORY = $(OBJECT_DIRECTORY)
OUTPUT_BINARY_DIRECTORY = $(OBJECT_DIRECTORY)
# Sorting removes duplicates
BUILD_DIRECTORIES := $(sort $(OBJECT_DIRECTORY) $(OUTPUT_BINARY_DIRECTORY) $(LISTING_DIRECTORY) )
#flags common to all targets
CFLAGS  = -DNRF52
# tried to include following cflag from twi_sensor example but caused bsp build errors
#CFLAGS += -DBSP_DEFINES_ONLY
CFLAGS += -DSOFTDEVICE_PRESENT
CFLAGS += -DBOARD_PCA10040
CFLAGS += -DNRF52_PAN_12
CFLAGS += -DNRF52_PAN_15
CFLAGS += -DNRF52_PAN_58
CFLAGS += -DNRF52_PAN_55
CFLAGS += -DNRF52_PAN_54
CFLAGS += -DNRF52_PAN_31
CFLAGS += -DNRF52_PAN_30
CFLAGS += -DNRF52_PAN_51
CFLAGS += -DNRF52_PAN_36
CFLAGS += -DNRF52_PAN_53
CFLAGS += -DNRF_LOG_USES_UART=1
CFLAGS += -DS132
CFLAGS += -DCONFIG_GPIO_AS_PINRESET
CFLAGS += -DBLE_STACK_SUPPORT_REQD
CFLAGS += -DSWI_DISABLE0
CFLAGS += -DNRF52_PAN_20
CFLAGS += -DNRF52_PAN_64
CFLAGS += -DNRF52_PAN_62
CFLAGS += -DNRF52_PAN_63
CFLAGS += -mcpu=cortex-m4
CFLAGS += -mthumb -mabi=aapcs --std=gnu99
CFLAGS += -Wall -Werror -O0 -g3
CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
# keep every function in separate section. This will allow linker to dump unused functions
CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
CFLAGS += -fno-builtin --short-enums
LDFLAGS += -Xlinker -Map=$(LISTING_DIRECTORY)/$(OUTPUT_FILENAME).map
LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
LDFLAGS += -mcpu=cortex-m4
LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
# let linker to dump unused sections
LDFLAGS += -Wl,--gc-sections
# use newlib in nano version
LDFLAGS += --specs=nano.specs -lc -lnosys
# Assembler flags
ASMFLAGS += -x assembler-with-cpp
ASMFLAGS += -DNRF52
ASMFLAGS += -DSOFTDEVICE_PRESENT
ASMFLAGS += -DBOARD_PCA10040
ASMFLAGS += -DNRF52_PAN_12
ASMFLAGS += -DNRF52_PAN_15
ASMFLAGS += -DNRF52_PAN_58
ASMFLAGS += -DNRF52_PAN_55
ASMFLAGS += -DNRF52_PAN_54
ASMFLAGS += -DNRF52_PAN_31
ASMFLAGS += -DNRF52_PAN_30
ASMFLAGS += -DNRF52_PAN_51
ASMFLAGS += -DNRF52_PAN_36
ASMFLAGS += -DNRF52_PAN_53
ASMFLAGS += -DNRF_LOG_USES_UART=1
ASMFLAGS += -DS132
ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
ASMFLAGS += -DBLE_STACK_SUPPORT_REQD
ASMFLAGS += -DSWI_DISABLE0
ASMFLAGS += -DNRF52_PAN_20
ASMFLAGS += -DNRF52_PAN_64
ASMFLAGS += -DNRF52_PAN_62
ASMFLAGS += -DNRF52_PAN_63
# tried to include following asmflag from twi_sensor example but caused bsp build errors
#ASMFLAGS += -DBSP_DEFINES_ONLY
#default target - first one defined
default: clean nrf52832_xxaa_s132
#building all targets
all: clean
	$(NO_ECHO)$(MAKE) -f $(MAKEFILE_NAME) -C $(MAKEFILE_DIR) -e cleanobj
	$(NO_ECHO)$(MAKE) -f $(MAKEFILE_NAME) -C $(MAKEFILE_DIR) -e nrf52832_xxaa_s132
#target for printing all targets
help:
	@echo following targets are available:
	@echo 	nrf52832_xxaa_s132
	@echo 	flash_softdevice
C_SOURCE_FILE_NAMES = $(notdir $(C_SOURCE_FILES))
C_PATHS = $(call remduplicates, $(dir $(C_SOURCE_FILES) ) )
C_OBJECTS = $(addprefix $(OBJECT_DIRECTORY)/, $(C_SOURCE_FILE_NAMES:.c=.o) )
ASM_SOURCE_FILE_NAMES = $(notdir $(ASM_SOURCE_FILES))
ASM_PATHS = $(call remduplicates, $(dir $(ASM_SOURCE_FILES) ))
ASM_OBJECTS = $(addprefix $(OBJECT_DIRECTORY)/, $(ASM_SOURCE_FILE_NAMES:.s=.o) )
vpath %.c $(C_PATHS)
vpath %.s $(ASM_PATHS)
OBJECTS = $(C_OBJECTS) $(ASM_OBJECTS)
nrf52832_xxaa_s132: OUTPUT_FILENAME := nrf52832_xxaa_s132
nrf52832_xxaa_s132: LINKER_SCRIPT=ble_app_uart_gcc_nrf52.ld
nrf52832_xxaa_s132: $(BUILD_DIRECTORIES) $(OBJECTS)
	@echo Linking target: $(OUTPUT_FILENAME).out
	$(NO_ECHO)$(CC) $(LDFLAGS) $(OBJECTS) $(LIBS) -lm -o $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out
	$(NO_ECHO)$(MAKE) -f $(MAKEFILE_NAME) -C $(MAKEFILE_DIR) -e finalize
## Create build directories
$(BUILD_DIRECTORIES):
	echo $(MAKEFILE_NAME)
	$(MK) $@
# Create objects from C SRC files
$(OBJECT_DIRECTORY)/%.o: %.c
	@echo Compiling file: $(notdir $<)
	$(NO_ECHO)$(CC) $(CFLAGS) $(INC_PATHS) -c -o $@ $<
# Assemble files
$(OBJECT_DIRECTORY)/%.o: %.s
	@echo Assembly file: $(notdir $<)
	$(NO_ECHO)$(CC) $(ASMFLAGS) $(INC_PATHS) -c -o $@ $<
# Link
$(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out: $(BUILD_DIRECTORIES) $(OBJECTS)
## Create binary .bin file from the .out file
$(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).bin: $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out
	@echo Preparing: $(OUTPUT_FILENAME).bin
	$(NO_ECHO)$(OBJCOPY) -O binary $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).bin
## Create binary .hex file from the .out file
$(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).hex: $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out
	@echo Preparing: $(OUTPUT_FILENAME).hex
	$(NO_ECHO)$(OBJCOPY) -O ihex $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).hex
finalize: genbin genhex echosize
genbin:
genhex:
echosize:
	-@echo ''
	$(NO_ECHO)$(SIZE) $(OUTPUT_BINARY_DIRECTORY)/$(OUTPUT_FILENAME).out
	-@echo ''
clean:
	$(RM) $(BUILD_DIRECTORIES)
cleanobj:
	$(RM) $(BUILD_DIRECTORIES)/*.o
flash: nrf52832_xxaa_s132
	@echo Flashing: $(OUTPUT_BINARY_DIRECTORY)/$<.hex
	nrfjprog --program $(OUTPUT_BINARY_DIRECTORY)/$<.hex -f nrf52  --sectorerase
	nrfjprog --reset -f nrf52
## Flash softdevice
flash_softdevice:
	@echo Flashing: s132_nrf52_2.0.0_softdevice.hex
	nrfjprog --program ../../../../../../components/softdevice/s132/hex/s132_nrf52_2.0.0_softdevice.hex -f nrf52 --chiperase
  • Seems like it can't find the TWI0_USE_EASY_DMA and TWI0_INSTANCE_INDEX defines which are defined in the sdk_config.h and nrf_drv_config.h files that are part of the original projects. Are you sure they are not missing from the files?
