I have implemented pwm as suggested in the info centre of nordiac semiconducter. But it showing the following error as shown below image.
Please Help if any one is aware of it.
Thank you.
Thank you.
Hello!
You have probably not include the path to the pwm library like here:
The path is probably different in your case.
You need to enable the PWM library in sdk_config.h, by setting #define APP_PWM_ENABLED 1. Look in the sdk_config.h file of the PWM library example if you cannot find the settings in your project.
Jørgen
Ya Thank you, It is compiled with zero errors. I enabled #define APP_PWM_ENABLED 1.But when ported on Board it is giving some FATAL error on uart.I added pwm set duty cycle to make sound on buzzer at alert_signal function.Any idea
You should try debugging using this method, to see which function call is failing and what error code is returned.
