Hi all,
I am using a nRF52-DK board to receive data from the USB port using Serial, and transmitting it using ESB to a second board. If I use either Serial or ESB individually, it works fine. I have a problem when using both together. (I have set #define APP_TIMER_CONFIG_SWI_NUMBER 1)
If I do this procedure:
- Receive a Serial packet
- Send a "transmit start" message back through Serial
- transmit the packet through ESB
- Send a "transmit done" message back through Serial
then the returned Serial data is incomplete / corrupted and it won't accept any more serial data.
I am sure that it is possible to use Serial and ESB together, does the program need any special configuration to do so?
