Hi, I have been modifying the MQTT Publish example for a product and found that the PUBACK message does not produce an event. The problem is in components/iot/mqtt/mqtt_transport.c. There is no handler for this event, it just falls into the default: which does nothing. I have added this code that does produce the event, in the routine mqtt_handle_rx_data(). If you need other MQTT events this is where and how to add them.
// Add code to handle an MQTT PUBACK message
case MQTT_PKT_TYPE_PUBACK:
MQTT_TRC("[MQTT]: Received PUBACK\r\n");
// Set event
evt.id = MQTT_EVT_PUBLISH_ACK;
evt.result = NRF_SUCCESS;
evt_cb = p_client->evt_cb;
err_code = NRF_SUCCESS;
