MQTT Reset ?
In the release notes for the IOT SDK (which as the MQTT examples) it says: "Once BLE link is disconnected, lwIP example applications no longer get a global prefix. The only way to start using the examples with the global prefix again is to restart the application." I need to disconnect the BLE link but must also preserve some application settings through the reset.
Thanks for the help. --jim schimpf
  • Found a workaround. If I modify the linker file to this:
    MEMORY
      FLASH (rx) : ORIGIN = 0x1f000, LENGTH = 0x61000
      /* Save area for config data */
      CONFIG(rw) :  ORIGIN = 0x20002800, LENGTH = 0x0100
      RAM (rwx) :  ORIGIN = 0x20002900, LENGTH = 0xd700
    SECTIONS {
        .mysaveBlock 0x20002800 (NOLOAD) :
        KEEP(*(.mysaveBlock))
    } > CONFIG
    and then define the variable I need to save as:
    PEG_CONTROL __attribute__((section (".mysaveBlock"))) pegControl;
    This area (256 bytes) is NOT cleared on RESET and so retains my values.
    MEMORY
    SECTIONS {
    } > CONFIG
