nRF52832 : PWM Driver Clock lower then 125kHz
Hey,
just wondering if its possible to lower the pwm driver clock of the nRF52832 to around 500Hz? Im working on a LED dimming application and the LED spots i use have really bad on/off times. Im getting much noise on the VCC which ends in a CPU reset when i dimm the spots to a lower value then 20% off time. So i tried it with the PWM Library with a lower pwm clock and it worked better then.
Now i need to know if its somehow possible to set the clock for the pwm driver lower then 125kHz. I looked in the datasheet but it seems like its not possible to set the clock directly to a lower freq. But maybe there is any other option to decrease the clock?
Thanks!
