SDK 13.0.0 Buttonless DFU won't enter boot mode
Starting notification and then writing 0x01 to the control point does not cause the Buttonless DFU to enter boot mode. LED #1 remains on.
Run time trace show:
APP:INFO:advertising is started
APP:INFO:Connected
APP:INFO:Received indication state 0, notification state 1
Log from LightBlue shows:
17:39:26.322 — Connected to nearby peripheral: Nordic_Buttonless
17:39:26.948 — Discovered nearby peripheral: (null) (RSSI: -94)
17:39:27.291 — Stopping search for nearby peripherals
17:39:36.236 — Characteristic (8EC90003-F315-4F60-9FB8-838830DAEA50) wrote new value: <01>
17:39:39.325 — Starting search for nearby peripherals
17:39:39.840 — Disconnecting from nearby peripheral: Nordic_Buttonless
17:39:39.854 — Disconnected from nearby peripheral Nordic_Buttonless
17:39:40.455 — Discovered nearby peripheral: (null) (RSSI: -78)
17:39:40.515 — Stopping search for nearby peripherals
  • Root cause is no BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST gets generated despite the fact wr_auth is set.
    156 char_uuid.type = p_dfu->uuid_type;
    157 char_uuid.uuid = BLE_DFU_BUTTONLESS_CHAR_UUID;
    158
    159 BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
    160 BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.write_perm);
    161
    162 attr_md.vloc = BLE_GATTS_VLOC_STACK;
    163 attr_md.rd_auth = 0;
    164 attr_md.wr_auth = 1;
    165 attr_md.vlen = 1;
    Trace
    APP:INFO:Connected
    :INFO:ble_dfu_on_ble_evt 10
    :INFO:ble_dfu_on_ble_evt 21
    :INFO:ble_dfu_on_ble_evt 22
    :INFO:ble_dfu_on_ble_evt 55
    :INFO:ble_dfu_on_ble_evt 50
    :INFO:on_write
    :INFO:ble_dfu_on_ble_evt 52
    :INFO:ble_dfu_on_ble_evt 12
  • Have you flashed the secure bootloader(boootloader_secure_ble example) along with the experimental_ble_app_buttonless_dfu example to your nRF5x device?
  • Yes. Holding Button 4 at power on puts the pca10040 into DFU mode. Secure DFU with the botton works. The Buttonless does not trigger going into DFU mode. If the BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST event is never received, DFU mode wont occur.
  • I tested this with an iPhone 5 and LightBlue Explorer, and I did not have any issues putting the device in bootloader mode. I also tested this with nRF Connect for Desktop, i.e. writing 0x0200 to the CCCD in order to enable notifications and then you write 0x01 to the Control Point Characteristic. Same story. Are you using the un-modified buttonless dfu example or have you modified/added buttonless dfu to another application?
  • This is using unmodified buttonless example as well.
