HRM Example on Sparkfun nRF52 board
Hi
I have this board: www.sparkfun.com/.../13990 connected to a PCA10040 Nordic board. I am able to write and debug the Sparkfun board (the blinky LED example). I am now trying to get the ANT+ HRM example to work.
I am using SDK v11.
My understanding is I need to first flash the SoftDevice to the Sparkfun board. I did so using the nRFgo Studio application. The SoftDevice I used was the ANT_s332_nrf52_2.0.1. Here is a screenshot after I flashed the softdevice:
image description
I am using Eclipse on OSX, with armgcc. I believe I need to change the Linker script to change the memory configurations. What I don't know is to what..
I started with the blinky example and my Linker script is as such:
    /* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  FLASH (rx) : ORIGIN = 0x0, LENGTH = 0x80000
  RAM (rwx) :  ORIGIN = 0x20000000, LENGTH = 0x10000
SECTIONS
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
} INSERT AFTER .data;
INCLUDE "nrf5x_common.ld"
But I am quite sure this will not work. I believe this will overwrite the SoftDevice..
Can anyone tell me what my linker script should be so that when I flash the HRM binary it does not overwrite the SoftDevice ? (I assume that's what I am trying to avoid). Please keep in mind that I am not using the exact HRM example but one that is slightly modified.
If there is anything else I have missed, please let me know.
Thanks
J
  • You can just use the same Memory configuration as the linker script for the gcc toolchain in our SDK, ble_ant_app_hrm_gcc_nrf52.ld. You'll find it in \examples\multiprotocol\ble_ant_app_hrm\pca10040\s332\armgcc. You may also have to add the pwr_mgmt_data section if you're using that in your modified example.
    SEARCH_DIR(.)
    MEMORY
      FLASH (rx) : ORIGIN = 0x27000, LENGTH = 0x59000
      RAM (rwx) :  ORIGIN = 0x20003800, LENGTH = 0xc800
    SECTIONS
      .fs_data :
        KEEP(*(.fs_data))
      } > RAM
  • Hi Shampoo,
    I also have the Sparkfun board and a Nordic pca10040 but I dont know how to connect them, do you have a sketch how did you connected them?
    I having problem everytime that I want to flash the sparkfun, due to the Triggering the Bootloader
    regards,
    David Caraveo
