Unable to Read or write MMA8652 registers using TWI
[https://drive.google.com/open?id=0ByjgT_Zt3YyJS2tKQko3cW10SlU]
hi i am working on MMA8652 i am working on mma7660 twi example in sdk11 for nrf52. i have changed the registers as the same way the MMA8652 need. here is my read and write functions
to read data:-
#define MMA8652_I2C_ADDR				(0x1D)
uint8_t	W_reg = MMA8652_REG_WHO_AM_I;
	err_code=nrf_drv_twi_tx(&m_twi_mma_8652, MMA8652_I2C_ADDR, &W_reg, sizeof(W_reg), false);
	nrf_delay_ms(5);
	err_code = nrf_drv_twi_rx(&m_twi_mma_8652, MMA8652_I2C_ADDR, &W_reg, sizeof(W_reg));
when i am going to run this the application is going to stuck.
and also i have one doubt. in sdk twi example there is one function for reading, in that example in twi handler directly reading from device address. and the result is going to structure instance with x,y,x,tilt.
here is that function
typedef struct
    elem_t  x;
    elem_t  y;
    elem_t  z;
    uint8_t tilt;
} sample;
err_code = nrf_drv_twi_rx(&m_twi_mma_8652, MMA8652_I2C_ADDR, (uint8_t*)&sample, sizeof(sample));
how it is possible to read directly from MMA8652_I2C_ADDR(0X1D)
if i am using same procedure i am getting x value is always 0 and y, z values are varying. is this procedure is correct to read x,y,z data from the accelerometer.
EDIT:-------
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context) { ret_code_t err_code; static sample_t m_sample;
switch(p_event->type)
case NRF_DRV_TWI_EVT_DONE:
	//string_send("1twirxsuc\r\n");
	if ((p_event->type == NRF_DRV_TWI_EVT_DONE) &&
			(p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX))
		if(m_set_mode_done != true)
			m_set_mode_done  = true;
			return;
		m_xfer_done = false;
		err_code = nrf_drv_twi_rx(&m_twi_mma_8652, 0X1D, (uint8_t*)&m_sample, sizeof(m_sample));
		if(err_code == NRF_SUCCESS){
			string_send("rx Done\r\n");
			string_send("rxfail\r\n");
			//string_send("2twi rx suc\r\n");
		//string_send("elsetwirx\r\n");
		read_data(&m_sample);
		m_xfer_done = true;
