Secure DFU - Issue in updating the application.
Hello, I am trying to implement OTA firmware update using Secure DFU.
SDK - 12.2
Softdevice - s132
Board - PCA10040 (nRF52)
I followed instructions mentioned here
Issues:
  • Once the bootloader code has been uploaded, device advertises as DFUTARG.
  • Able to connect to the device.
  • When I select .zip packet or .bin + .dat package, the following changes can be seen: "Initialising", "DFU starting" followed by immediate "Disconnected".
  • This is common to both nRF Connect and nRF Toolbox.
  • The procedure works fine with test_bootloader and test_hrm example.
  • Also, I am not generating a bootloader settings file as I just want to work with default settings.
Am I missing something, that is not mentioned on the link provided above?
  • The answer is pretty simple and the issue was due to my carelessness.
    The link discusses secure DFU using s132 v4.0.2. Thus --sd-req is 0x98.
    Since, I am using s132 v3.0.0, --sd-req should be 0x8C.
