Weird Problem where Segger RTT breaks if using more than 8kB of RAM
I started a new software project on the nRF52832 a couple of weeks ago. I've been using Segger RTT for a lot of debugging with no problem throughout the beginning of the process. I've recently hit an issue where the Segger RTT printf statements stop showing up when I use more than 8kB of RAM. I should have almost 49,000 bytes of RAM remaining, so I'm nowhere near close to running out of RAM.
I've gotten to the point where I can compile my code with or without a single global uint32_t variable and if that variable is included the Segger RTT stuff will not work properly (note that as far as I can tell, everything else appears to work properly).
I'm using the S132 Soft Device and am using GCC to compile the code.
Here are the code size results from compilation:
   text	   data	    bss
  40860	    176	   7828
This uses 8004 Bytes of RAM, and that's when the Segger RTT breaks.
Here's the linker script that I'm using:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  FLASH (rx) : ORIGIN = 0x1f000, LENGTH = 0x61000	/* 397312 Bytes */
  RAM (rwx) :  ORIGIN = 0x20002128, LENGTH = 0xded8	/* 57048 Bytes */
SECTIONS
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
} INSERT AFTER .data;
INCLUDE "nrf5x_common.ld"
EDIT: I realized it might be worth mentioning that I'm allocating 4608 Bytes of RAM via the SDK provided memory manager.
