BLE Advertising, a beginner's tutorial
Hello everyone,
Lately I have been struggling while trying to run "BLE Advertising, a beginner's tutorial". My hardware consists of NRF51822 and PCA1000 dongle. I use SDK_11.0.0 and the example provided at github github.com/.../nrf51-ble-tutorial-advertising . I copy the folder "nrf5x-ble-tutorial-advertising" to "your_SDK_folder\examples\ble_peripheral". main.c file is found in the folder "your_SDK_folder\examples\ble_peripheral\nrf5x-ble-tutorial-advertising" like in tutorial said.
After that I change memory options to this: image description
Keil compiles it without errors or warnings: image description
Lastly, Master Control Panel can not find my "HelloWorld" device: image description
Moreover, I have tried the modified BLE_UART application of my colegue 's with the same tools and the device was found by the Master Conrol Panel software.
Any ideas what may be causing the problem? I would appreciate your help.
...EDITED:
While debugging the code stucks at this point: image description image description
  • Can you try configuring the RAM and ROM settings like this:
    image description
    Your settings doesn't match the Softdevice you should use which is S130 V2 settings.
  • Happy to help.
    In general you should go to the file pointed to by p_file_name and look at line 'line_num'. There you will usually see a call to APP_ERROR_CHECK(error_code). Then just above that there is code looking something like this:
    error_code = some_function();
    Now go to the declaration of some_function() in the header files or search for the function at infocenter.nordicsemi.com to find out what the error means.
  • Happy to help.
