Hi, I’m using nRF52840 with softdevice s140 and nRF5 SDK v13.0.0 and I’m having some issues regarding the optimization set up for the IAR Compiler (IAR Embedded Workbench v7.70.1). The application that I’m developing works as follows:
Pressing the Button 1 of the nRF52480-Preview-DK the device will work as peripheral, and pressing the Button 2 the device will work as central. The ble_stack_init() function looks like:
void ble_stack_init(void)
ret_code_t sErrCode;
ble_cfg_t sBleCfg;
uint32_t u32RamStart = 0;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
sErrCode = softdevice_app_ram_start_get(&u32RamStart);
APP_ERROR_CHECK(sErrCode);
u32RamStart = 536880624;
memset(&sBleCfg, 0, sizeof(sBleCfg));
sBleCfg.gap_cfg.role_count_cfg.periph_role_count = 1u;
sBleCfg.gap_cfg.role_count_cfg.central_role_count = 1u;
sBleCfg.gap_cfg.role_count_cfg.central_sec_count = 0u;
sErrCode = sd_ble_cfg_set(BLE_GAP_CFG_ROLE_COUNT, &sBleCfg, u32RamStart);
sBleCfg.conn_cfg.params.gap_conn_cfg.conn_count = 2;
sBleCfg.conn_cfg.params.gap_conn_cfg.event_length = BLE_GAP_EVENT_LENGTH_DEFAULT;
sBleCfg.conn_cfg.conn_cfg_tag = APP_CONN_CFG_TAG;
sErrCode = sd_ble_cfg_set(BLE_CONN_CFG_GAP, &sBleCfg, u32RamStart);
// Enable BLE stack.
sErrCode = softdevice_enable(&u32RamStart);
// Subscribe for BLE events.
sErrCode = softdevice_ble_evt_handler_set(ble_fnBleEvtDispatch_vo);
My application is based on the experimental example of experimental_ble_app_blinky. The problem is that when the Optimization is set to HIGH, the program resets the SoC right after BLE advertising or scanning is started so it is impossible to trace back the origin of the error.
Furthermore, if the Optimization is set to NONE, the BLE advertising and scanning seems to work, but the program does not recognize the press of the buttons. It seems that there is a problem with the button library.
Has anyone faced the same kind of problem?
Thank you in advance.
