Hello Nordic, i am trying to interface BME280 with nordic nRF52 and SDK v 12.02 using twi_peripheral but i am unable to do it. here in example they are using ls75b whereas i am using BME280. I extracted the BME drivers in root along with BME280 arduino library but i can´t find a way out. Hoping for some valuable pointers.
Thanks in advance!!
#define MAX_PENDING_TRANSACTIONS 5
#define APP_TIMER_PRESCALER 0
#define APP_TIMER_OP_QUEUE_SIZE 2
// Pin number for indicating communication with sensors.
#ifdef BSP_LED_3
#define READ_ALL_INDICATOR BSP_BOARD_LED_3
#else
#error "Please choose an output pin"
static app_twi_t m_app_twi = APP_TWI_INSTANCE(0);
static nrf_drv_rtc_t const m_rtc = NRF_DRV_RTC_INSTANCE(0);
// Buffer for data read from sensors.
#define BUFFER_SIZE 11
static uint8_t m_buffer[BUFFER_SIZE];
// Data structures needed for averaging of data read from sensors.
// [max 32, otherwise "int16_t" won't be sufficient to hold the sum
// of temperature samples]
#define NUMBER_OF_SAMPLES 16
typedef struct
int16_t temp;
int16_t x;
int16_t y;
int16_t z;
} sum_t;
static sum_t m_sum = { 0, 0, 0, 0 };
typedef struct
// [use bit fields to fit whole structure into one 32-bit word]
int16_t temp : 11;
int8_t x : 6;
int8_t y : 6;
int8_t z : 6;
} sample_t;
static sample_t m_samples[NUMBER_OF_SAMPLES] = { { 0, 0, 0, 0 } };
static uint8_t m_sample_idx = 0;
// Value previously read from MMA7660's Tilt register - used to detect change
// in orientation, shake signaling etc.
static uint8_t m_prev_tilt = 0;
#if defined( __GNUC__ ) && (__LINT__ == 0)
// This is required if one wants to use floating-point values in 'printf'
// (by default this feature is not linked together with newlib-nano).
// Please note, however, that this adds about 13 kB code footprint...
__ASM(".global _printf_float");
// Reading of data from sensors - current temperature from bme280 and from
// MMA7660: X, Y, Z and tilt status.
#if (BUFFER_SIZE < 6)
#error Buffer too small.
#define GET_ACC_VALUE(axis, reg_data) \
do { \
if (MMA7660_DATA_IS_VALID(reg_data)) \
axis = MMA7660_GET_ACC(reg_data); \
} while (0)
void read_all_cb(ret_code_t result, void * p_user_data)
if (result != NRF_SUCCESS)
NRF_LOG_INFO("read_all_cb - error: %d\r\n", (int)result);
return;
sample_t * p_sample = &m_samples[m_sample_idx];
m_sum.temp -= p_sample->temp;
m_sum.x -= p_sample->x;
m_sum.y -= p_sample->y;
m_sum.z -= p_sample->z;
uint8_t temp_hi = m_buffer[0];
uint8_t temp_lo = m_buffer[1];
uint8_t x_out = m_buffer[2];
uint8_t y_out = m_buffer[3];
uint8_t z_out = m_buffer[4];
uint8_t tilt = m_buffer[5];
p_sample->temp = bme280_GET_TEMPERATURE_VALUE(temp_hi, temp_lo);
GET_ACC_VALUE(p_sample->x, x_out);
GET_ACC_VALUE(p_sample->y, y_out);
GET_ACC_VALUE(p_sample->z, z_out);
if (!MMA7660_DATA_IS_VALID(tilt))
tilt = m_prev_tilt;
m_sum.temp += p_sample->temp;
m_sum.x += p_sample->x;
m_sum.y += p_sample->y;
m_sum.z += p_sample->z;
++m_sample_idx;
if (m_sample_idx >= NUMBER_OF_SAMPLES)
m_sample_idx = 0;
// Show current average values every time sample index rolls over (for RTC
// ticking at 32 Hz and 16 samples it will be every 500 ms) or when tilt
// status changes.
if (m_sample_idx == 0 || (m_prev_tilt && m_prev_tilt != tilt))
char const * orientation;
switch (MMA7660_GET_ORIENTATION(tilt))
case MMA7660_ORIENTATION_LEFT: orientation = "LEFT"; break;
case MMA7660_ORIENTATION_RIGHT: orientation = "RIGHT"; break;
case MMA7660_ORIENTATION_DOWN: orientation = "DOWN"; break;
case MMA7660_ORIENTATION_UP: orientation = "UP"; break;
default: orientation = "?"; break;
NRF_LOG_INFO("Temp: " NRF_LOG_FLOAT_MARKER " | X: %3d, Y: %3d, Z: %3d ",
NRF_LOG_FLOAT((float)((m_sum.temp * 0.125) / NUMBER_OF_SAMPLES)),
m_sum.x / NUMBER_OF_SAMPLES,
m_sum.y / NUMBER_OF_SAMPLES,
m_sum.z / NUMBER_OF_SAMPLES);
NRF_LOG_RAW_INFO("| %s%s%s\r\n",
(uint32_t)orientation,
(uint32_t)(MMA7660_TAP_DETECTED(tilt) ? " TAP" : ""),
(uint32_t)(MMA7660_SHAKE_DETECTED(tilt) ? " SHAKE" : ""));
m_prev_tilt = tilt;
static void read_all(void)
// Signal on LED that something is going on.
bsp_board_led_invert(READ_ALL_INDICATOR);
// [these structures have to be "static" - they cannot be placed on stack
// since the transaction is scheduled and these structures most likely
// will be referred after this function returns]
static app_twi_transfer_t const transfers[] =
bme280_READ_TEMP(&m_buffer[0])
MMA7660_READ_XYZ_AND_TILT(&m_buffer[2])
static app_twi_transaction_t const transaction =
.callback = read_all_cb,
.p_user_data = NULL,
.p_transfers = transfers,
.number_of_transfers = sizeof(transfers) / sizeof(transfers[0])
APP_ERROR_CHECK(app_twi_schedule(&m_app_twi, &transaction));
#if (BUFFER_SIZE < 7)
static void read_bme280_registers_cb(ret_code_t result, void * p_user_data)
NRF_LOG_INFO("read_bme280_registers_cb - error: %d\r\n", (int)result);
return;
NRF_LOG_INFO("bme280:\r\n");
NRF_LOG_HEXDUMP_INFO(m_buffer, 7);
static void read_bme280_registers(void)
bme280_READ(&bme280_conf_reg_addr, &m_buffer[0], 1),
bme280_READ(&bme280_temp_reg_addr, &m_buffer[1], 2),
bme280_READ(&bme280_tos_reg_addr, &m_buffer[3], 2),
bme280_READ(&bme280_thyst_reg_addr, &m_buffer[5], 2)
.callback = read_bme280_registers_cb,
#if (BUFFER_SIZE < MMA7660_NUMBER_OF_REGISTERS)
static void read_mma7660_registers_cb(ret_code_t result, void * p_user_data)
NRF_LOG_INFO("read_mma7660_registers_cb - error: %d\r\n", (int)result);
return;
NRF_LOG_INFO("MMA7660:\r\n");
NRF_LOG_HEXDUMP_INFO(m_buffer, MMA7660_NUMBER_OF_REGISTERS);
static void read_mma7660_registers(void)
MMA7660_READ(&mma7660_xout_reg_addr,
.callback = read_mma7660_registers_cb,
// Buttons handling (by means of BSP).
static void bsp_event_handler(bsp_event_t event)
// Each time the button 1 or 4 is pushed we start a transaction reading
// values of all registers from bme280 or MMA7660 respectively.
switch (event)
case BSP_EVENT_KEY_0: // Button 1 pushed.
read_bme280_registers();
case BSP_EVENT_KEY_3: // Button 4 pushed.
read_mma7660_registers();
static void bsp_config(void)
uint32_t err_code;
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
err_code = bsp_init(BSP_INIT_BUTTONS,
APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
bsp_event_handler);
// TWI (with transaction manager) initialization.
static void twi_config(void)
uint32_t err_code;
nrf_drv_twi_config_t const config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
.clear_bus_init = false
APP_TWI_INIT(&m_app_twi, &config, MAX_PENDING_TRANSACTIONS, err_code);
// RTC tick events generation.
static void rtc_handler(nrf_drv_rtc_int_type_t int_type)
if (int_type == NRF_DRV_RTC_INT_TICK)
// On each RTC tick (their frequency is set in "nrf_drv_config.h")
// we read data from our sensors.
read_all();
static void rtc_config(void)
uint32_t err_code;
// Initialize RTC instance with default configuration.
nrf_drv_rtc_config_t config = NRF_DRV_RTC_DEFAULT_CONFIG;
config.prescaler = RTC_FREQ_TO_PRESCALER(32); //Set RTC frequency to 32Hz
err_code = nrf_drv_rtc_init(&m_rtc, &config, rtc_handler);
// Enable tick event and interrupt.
nrf_drv_rtc_tick_enable(&m_rtc, true);
// Power on RTC instance.
nrf_drv_rtc_enable(&m_rtc);
static void lfclk_config(void)
uint32_t err_code;
err_code = nrf_drv_clock_init();
bsp_board_leds_init();
// Start internal LFCLK XTAL oscillator - it is needed by BSP to handle
// buttons with the use of APP_TIMER and for "read_all" ticks generation
// (by RTC).
lfclk_config();
bsp_config();
NRF_LOG_INFO("TWI master example\r\n");
NRF_LOG_FLUSH();
twi_config();
// Initialize sensors.
APP_ERROR_CHECK(app_twi_perform(&m_app_twi, bme280_init_transfers,
bme280_INIT_TRANSFER_COUNT, NULL));
APP_ERROR_CHECK(app_twi_perform(&m_app_twi, mma7660_init_transfers,
MMA7660_INIT_TRANSFER_COUNT, NULL));
rtc_config();
while (true)
__WFI();
NRF_LOG_FLUSH();
