On our project we're using a Raspberry Pi 3 compute module with custom hardware and 2x nRF51 SoC running HCI from Zephyr.
We'll be delivering more than 150 of those devices, that means more than 300 nRF51 and flashing each one of them manually is boring and time consuming. So when I figured I could use OpenOCD directly on the Raspberry Pi I've started planning to have SWDIO and SWDCLK wired directly to the GPIO so on 1st boot the Pi could flash the bluetooth firmware.
But of course it's not working. That would be too easy.
I compiled without issues OpenOCD directly on the Pi following those tutorials HERE and HERE.
Connecting a ST-Link/V2 on the Raspberry Pi USB port it all work as it should. Connects to the nRF51, erase, flash, run.
Now using directly the Pi GPIO, I've connected 3V3, GND from the Pi-CM3-Dev Kit to the nRF51 and SWD to GPIO 24 and 25. There's no connection for SRST or TRST on the module.
I'm using openocd.cfg as follows
source [find interface/raspberrypi2-native.cfg]
bcm2835gpio_swd_nums 25 24
transport select swd
# target
source [find target/nrf51.cfg]
init
targets
I've tried adding several reset_config parameters on this config such as srst_only, srst_nogate and none as from the tutorials, but nothing changed the resul. Open calling sudo openocd -f ocd.cfg I always get the following error:
Error: Could not initialize the debug port
Open On-Chip Debugger 0.10.0+dev-00111-gca9dcc8 (2017-04-24-15:30)
Licensed under GNU GPL v2
For bug reports, read
openocd.org/.../bugs.html
BCM2835 GPIO nums: swclk = 25, swdio = 24
cortex_m reset_config sysresetreq
adapter speed: 1000 kHz
Info : BCM2835 GPIO JTAG/SWD bitbang driver
Info : SWD only mode enabled (specify tck, tms, tdi and tdo gpios to add JTAG mode)
Info : clock speed 1001 kHz
Info : SWD DPIDR 0x00150634
TargetName Type Endian TapName State
0* nrf51.cpu cortex_m little nrf51.cpu unknown
I'm under the assumption that raspberrypi2-native.cfg is compatible with Raspberry Pi 3 but we've just ordered a raspberrypi2 to the office to test on it as well.
Is there anything I'm doing wrong here? Did someone experience that before? The only thing I found was a thread on sourceforge for the OpenOCD project, but it was from 2015 and all code patches suggested there is already included on the latest release.
Maybe someone can suggest another software to accomplish the same thing.
