Nordik UART app with Multiple service reception
I need to receive both UART Service data and HRS service data on the app.
Currently I have seen on Nordik Connect app , both the services can be found and can connect and receive data.
I need to do same with my app using nordik UART App code.
I have changed UART profile to HRS profile and code was working, i was receiving Nordik HRS service data.
But i want both services should be used and receives data. so i have prepare separate UARTService_HRS for hrs profile in the same code.also added needed changed.but it gives error null pointer exception on BLEGattService.
Please help
  • Please let me know if you can make it work with just the HRS profile, no UART ? I suggest you to test as follow:
    1 - Make a firmware with just HRS (you can use our hrs example) then make an app with just HRS and make sure it works.
    2 - Make a firmware with HRS and UART then make an app with just HRS and test
    3 - Try to add UART in to the HRS app and test again
    I don't see any reason why only UART work but not HRS.
    You may want to capture a sniffer trace so I can see what happens over the air. Make sure CCCD is enabled for both services.
