Whitelisting
I'm working on nRF52832-DK with SDK11 on linux.
Is there an example to use whitelisting ? I'm trying to use HIDS_Mouse but it's not working.
How can I write manually a specifical MAC adress to add on the list ?
Thank you.
For now I have try in " on_adv_evt " :
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "boards.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "pstorage.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "our_service.h"
#include "nrf_drv_gpiote.h"
#include "nrf_delay.h"
#include "nrf_drv_timer.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT  1
#define CENTRAL_LINK_COUNT               0
#define PERIPHERAL_LINK_COUNT            1
#define DEVICE_NAME                      "OurApp"
#define MANUFACTURER_NAME                "Mine"
#define APP_ADV_INTERVAL                 300
#define APP_ADV_TIMEOUT_IN_SECONDS       20
#define APP_TIMER_PRESCALER              0
#define APP_RTC_PRESCALER                22
#define APP_TIMER_OP_QUEUE_SIZE          4
#define MIN_CONN_INTERVAL                MSEC_TO_UNITS(100, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL                MSEC_TO_UNITS(200, UNIT_1_25_MS)
#define SLAVE_LATENCY                    0
#define CONN_SUP_TIMEOUT                 MSEC_TO_UNITS(4000, UNIT_10_MS)
#define FIRST_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER)
#define NEXT_CONN_PARAMS_UPDATE_DELAY    APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)
#define MAX_CONN_PARAMS_UPDATE_COUNT     3
#define SEC_PARAM_BOND                   1
#define SEC_PARAM_MITM                   0
#define SEC_PARAM_IO_CAPABILITIES        BLE_GAP_IO_CAPS_NONE
#define SEC_PARAM_OOB                    0
#define SEC_PARAM_MIN_KEY_SIZE           7
#define SEC_PARAM_MAX_KEY_SIZE           16
#define DEAD_BEEF                        0xDEADBEEF
#define OUR_CHAR_TIMER_INTERVAL         APP_TIMER_TICKS(500, APP_TIMER_PRESCALER)
#define APP_ADV_FAST_INTERVAL           0x0028
#define APP_ADV_SLOW_INTERVAL           0x0C80
#define APP_ADV_FAST_TIMEOUT            30
#define APP_ADV_SLOW_TIMEOUT            180
APP_TIMER_DEF(m_our_char_timer_id);
static ble_uuid_t m_adv_uuids[] = {{0x9999, BLE_UUID_TYPE_BLE}};
const nrf_drv_timer_t TIMER_LED = NRF_DRV_TIMER_INSTANCE(1);
static dm_application_instance_t        m_app_handle;
static uint16_t  m_conn_handle = BLE_CONN_HANDLE_INVALID;
static nrf_ppi_channel_t       m_ppi_channel;
ble_os_t m_our_service;
static void timer_timeout_handler(void * p_context)
     nrf_gpio_pin_toggle(LED_2);
static void timers_init(void)
{   uint32_t err_code;
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    app_timer_create(&m_our_char_timer_id, APP_TIMER_MODE_REPEATED, timer_timeout_handler);
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    our_service_init(&m_our_service);
    uint32_t err_code;
    APP_ERROR_HANDLER(nrf_error);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
          ble_advertising_start(BLE_ADV_MODE_FAST); //fast advertising will connect to any peer device, or filter with a whitelist if one exists.
            //sleep_mode_enter();
        case BLE_ADV_EVT_SLOW:
            err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING_SLOW);
        case BLE_ADV_EVT_WHITELIST_REQUEST:
                   ble_gap_whitelist_t  whitelist;
                   ble_gap_addr_t*      p_whitelist_addr[3];
                   ble_gap_addr_t       whitelist_sensor_1     = {BLE_GAP_ADDR_TYPE_RANDOM_STATIC,{0xCE,0x1B,0x66,0x29,0xAE,0xEE}};
                   ble_gap_addr_t       whitelist_sensor_2     = {BLE_GAP_ADDR_TYPE_RANDOM_STATIC,{0xDB,0xAC,0x83,0xC9,0x50,0x16}};
                   ble_gap_addr_t       whitelist_sync_beacon  = {BLE_GAP_ADDR_TYPE_PUBLIC,{0x26,0xB3,0x55,0x50,0xCE,0x11}};  //BLE IPHONE MAC ADRESS
                   p_whitelist_addr[0]     = &whitelist_sensor_1;
                   p_whitelist_addr[1]     = &whitelist_sensor_2;
                   p_whitelist_addr[2]     = &whitelist_sync_beacon;
                   whitelist.addr_count    = 3;
                   whitelist.pp_addrs      =  p_whitelist_addr;
                   whitelist.pp_irks       = NULL;
                   whitelist.irk_count     = 0;
                    //err_code = dm_whitelist_create(&m_app_handle, &whitelist);
                    //APP_ERROR_CHECK(err_code);
                    err_code = ble_advertising_whitelist_reply(&whitelist);
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            app_timer_start(m_our_char_timer_id, OUR_CHAR_TIMER_INTERVAL, NULL);
            app_timer_stop(m_our_char_timer_id);
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    dm_ble_evt_handler(p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
    ble_our_service_on_ble_evt(&m_our_service, p_ble_evt);
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    ble_enable_params.gatts_enable_params.service_changed = IS_SRVC_CHANGED_CHARACT_PRESENT;
    err_code = softdevice_enable(&ble_enable_params);
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
                                           dm_event_t const  * p_event,
                                           ret_code_t        event_result)
    APP_ERROR_CHECK(event_result);
#ifdef BLE_DFU_APP_SUPPORT
    if (p_event->event_id == DM_EVT_LINK_SECURED)
        app_context_load(p_handle);
#endif // BLE_DFU_APP_SUPPORT
    return NRF_SUCCESS;
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
    register_param.sec_param.bond         = SEC_PARAM_BOND;
    register_param.sec_param.mitm         = SEC_PARAM_MITM;
    register_param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    register_param.sec_param.oob          = SEC_PARAM_OOB;
    register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    uint32_t      err_code;
    ble_advdata_t advdata;
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    advdata.include_appearance      = true;
    advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    advdata.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_whitelist_enabled = BLE_ADV_WHITELIST_ENABLED; //added this
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
    uint32_t err_code;
    bool erase_bonds;
    timers_init();
    gpio_init();
    ble_stack_init();
    device_manager_init(erase_bonds);
    gap_params_init();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
      power_manage();
  • I can't establish connection with whitelist. My code is advertising normally.
    I'm using ble_app_hids_mouse with scan_start from the other post.
  • Just to be clear, you shouldn't call scan_start if you want to advertise. Do something like:
       ble_gap_addr_t       whitelist_sync_beacon  = {BLE_GAP_ADDR_TYPE_RANDOM_STATIC,{0xF9,0x3C,0xDC,0x2D,0xA9,0xA3}};
    It's not working. It's strange because i'm able to connect with a phone who is not on the withelist ( with NRF Connect app). The others device who are on the whitelist are not able to be connected.
    Is it possible to use the bluetooth static adress ( found on phone settings) ?
    I'have try different solution without succes.
    With that :
            ble_gap_addr_t    * p_whitelist_addr[0];
            ble_gap_irk_t     * p_whitelist_irk[0];
            whitelist.addr_count = 0;
            whitelist.pp_irks    = p_whitelist_irk;
    I'm still able to connect to my device even with all the 0 .. Thank you
  • Devices in the whitelist are not able to connect? But others are? That doesn't make any sense. What is the meaning of the code you included in your last comment? I don't understand.
