I use SDK9 nRF51. I use white list. When I want to delete all bounded devices, I call this function. But it doesn't work. It not deleted. Why I can't to delete bounded devices?
Hi, are you not getting any DM_EVT_DEVICE_CONTEXT_DELETED events after calling this api? There should be one event for each deleted entry.
Example (does a sys reset once finished):
static uint32_t device_manager_evt_handler(dm_handle_t const * p_handle,
dm_event_t const * p_event,
ret_code_t event_result)
uint32_t err_code;
static bool device_delete_all_started;
// Recovery in the event of DM_DEVICE_CONTEXT_FULL
if(event_result == DM_DEVICE_CONTEXT_FULL)
/* Clear all devices from the bond table*/
err_code = dm_device_delete_all(&m_app_handle);
device_delete_all_started = true;
if (p_event->event_id ==DM_EVT_DEVICE_CONTEXT_DELETED)
/* Wait for all devices to be cleared before perfoming a sys reset */
if(device_delete_all_started && (p_handle->device_id == DEVICE_MANAGER_MAX_BONDS -1))
err_code = sd_nvic_SystemReset();
Thanks for anwer. I remarked that this
dm_device_delete_all(& m_dm_app_id);
function work only when nRF51 in advertiser mode.
When nRF51 in central mode (I use s130), this function doesn't work.
Why?
Does dm_device_delete_all() an error code?
when I in central mose (s130), and call this function, return error code 0x00000000 for 1 second erased all bounded devices, than again has 2 bounded devices like before. is it normal?
No, the bonds should be erased in flash as soon as the erase is completed. Did you wait for the two DM_EVT_DEVICE_CONTEXT_DELETED events before you checked?
