Corelocation Ibeacon Detection Range
Hi guys
I have been working with a nordic ble device (NRF51822) configured as a Beacon. I am implementing an IOS app, using Apple framework " CoreLocation". My goal is to detect beacons on background mode. Until now, I am able to detect beacons only in a very small range (3.9 meters).
Is this normal? Is there a way to improve this behavior?
I tested the same beacons on an Android app (background mode) and the range is much better.
Ibeacon properties:
  • Trasmission power: 0 Db
  • Softdevice : S130
  • Advertising interval: 100ms
Thanks in advance
  • Hi @fercholas !, something has to be wrong, as you see (from the CoreLocation docs):
    The specific threshold distances are determined by the hardware and the location technologies that are currently available. For example, if Wi-Fi is disabled, region monitoring is significantly less accurate. However, for testing purposes, you can assume that the minimum distance is approximately 200 meters.
    Try changing the transmission power to -30 and see how things change, you can see the valid values in this page
    Then follow the code in Listing 2-3 found here
    You might want to read the broadcast data of the beacon to see if it does indeed have the proper transmission power in the advertised data so iOS is able to predict the beacon's proximity
    another important note you need to have in mind is that the device need to be configured as an iBeacon and not any other. only iBeacons can be detected in the background and are compatible with corelocation, etc..
  • Is it possible to fire the DidEnterRegion event 50 meter from the beacon?
