About the bluetooth Uart data sent
Because I need to receive the serial interface in the event handler of the serial data communication protocol (custom) send out via bluetooth, a set of protocols to 25 bytes, to head to tail, the 20 bytes sent via bluetooth;Assistant when I use a serial port, the importation of set protocol, a total of 40 to 1000 bytes, sent at the same time, you can't get a data on the APP, but I keep the baud rate, can get all the data in the APP end, so I want to use the scheduler in serial event handler, to avoid interrupt handling process is too long cause may lose the interrupt signal, then to solve this problem, I want to know how to use the scheduler.
