bond question with Peer Manager
I use example ble_app_hrs_pca10040_s132 with SDK12.2.0 to test bonding function.It works as a server and it is bound by client. But I fail to bond. It seems that example has peer manager and also has bond function.
So do I have to do some modification on this example to test bonding function? If yes, what should I do?
Thanks a lot!
  • It seems you are mixing up bonding with whitelisting. Even if a device has a bond with another device it can connect with other devices.
    But if you are a peripheral and advertise with a whitelist, you can put the address of a bonded peer into the whitelist, and then only accept connection requests from the specific peer.
    ble_app_hrs supports bonding, but doesn't implement whitelisting, for that you can have a look at the ble_app_hids_keyboard or ble_app_hids_mouse examples.
  • That is to say I want to add my ble address into whitelist and set it into softdevice without using bonding. Because when bonding, peer_id which is related to ble address will be added into whitelist_peers[].It is not 48-bit ble address. So I cannot use pm_whitelist_set(). Thanks a lot!
