Timer1 max value
I'm working on nrf52832-DK with SDK11 on Timer1. I can't use TIMER0 because I'm using also the softdevice.
My code source is :
//handler
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch(event_type)
        case NRF_TIMER_EVENT_COMPARE1:
                  nrf_drv_gpiote_out_set(PIN_06);
         //nrf_drv_timer_compare_int_disable(&TIMER, NRF_TIMER_CC_CHANNEL0);
            //Do nothing.
main :
                    time_us = 5000; //Time(in us) between consecutive compare events.
                    nrf_drv_timer_clear(&TIMER);
                    time_ticks = nrf_drv_timer_us_to_ticks(&TIMER, time_us);
                    nrf_drv_timer_compare(&TIMER_LED, NRF_TIMER_CC_CHANNEL1, time_ticks, true);
                    nrf_drv_timer_enable(&TIMER);
I want to configure my Timer1 between 1us and 10000us. I have seen that Timer 0 is BIT_WIDTH 16 bits so the maximum value can be theorically 65535 ?
But my timer restart at the value of 4097. Is it normal ? How can I configure it to set the value from 0-10000 us ?
Thank you very much
