softdevice_enable() does not return on nRF52, sdk12.0.0
I am using s132_nrf52_3.0.0_softdevice.hex and sdk12 and compiling with arm-none-eabi-gcc. The problem is that the bluetooth set up just jams at:
   // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
So I do not get any error code, because the softdevice_enable never returns. I am thinking could the problem have something to do with the define in the Makefile:
CFLAGS += -DNRF_SD_BLE_API_VERSION=3
Is that correct for the softdevice version I am using? Or what could be the reason for the problem?
  • It looks like NRF_LOG_INIT() must be called in order to get softdevice working. This is a bit bad dependency.
  • I need to check that. You are using SDK 12.0.0?
  • Yep, that is the SDK I am using. The softdevice_enable() now prints
    **SDH:INFO:sd_ble_enable: RAM START at 0x20002168
    SDH:WARNING:sd_ble_enable: app_ram_base should be adjusted to 0x20002128
    SDH:WARNING:ram size should be adjusted to 0xded8**
    So I assume those print outs will fail if NRF_LOG is not initialized. When I adjust those RAM values correctly, it still prints
    SDH:INFO:sd_ble_enable: RAM START at 0x20002128
    So maybe NRF_LOG_INIT() is needed even then?
  • After removing "NRF_LOG_INIT()", did you also set NRF_LOG_ENABLED to 0 in sdk_config.h?
  • Not sure. But since the softdevice is not recompiled anyway, would it have any effect in this case?
1 2
