Timer expires instantly
Hi all,
I have seen a pair of questions (this and this) that I think have something to do with this, but didn't find a solution.
I have a custom board with a button which acts as a reset button. This button must be pressed during 3 seconds to reset the device (otherwise it has no effect). I do this activating a 3 seconds timer when the button is pressed, and when the timer expires, I reset the device. If I release the button before, I stop the timer.
Normally this goes well, but I have found that after waiting for some time (maybe 5 minutes), the next time I press the button, the reset occurs instantly (because the timer that should expire in 3 seconds does it instantly). I attach the relevant part of the code:
Buttons interrupt handler:
static void button_evt_handler(uint8_t pin_no, uint8_t button_action)
	if (button_action == APP_BUTTON_PUSH && pin_no == PIN_RESET_BUTTON)
        start_reset_button_timer();
    }else if(button_action == APP_BUTTON_RELEASE && pin_no == PIN_RESET_BUTTON)
		stop_reset_button_timer();
Timer functions (I init the timer once at the beginning of the code):
static void reset_button_handler(void * p_context) // After 3 seconds pressing the button we get here
	// Factory values
	set_param_default_values(&param_ibk); // Set default values in flash and reset
	uint32_t err_code = access_paramIBK_flash(&param_ibk, ES_FLASH_ACCESS_WRITE);
	// Reset after flash
	flag_reset=true;
void init_reset_button_timer(void)
	uint32_t err_code;
	err_code = app_timer_create(&reset_button_timer, APP_TIMER_MODE_SINGLE_SHOT, reset_button_handler);
void start_reset_button_timer(void)
	uint32_t err_code;
	err_code = app_timer_start(reset_button_timer, APP_TIMER_TICKS(TIME_RESET_BUTTON, APP_TIMER_PRESCALER), NULL); // After 3 seconds will reset the device if not stopped before
void stop_reset_button_timer(void)
	app_timer_stop(reset_button_timer); // Button released, timer stopped
and TIME_RESET_BUTTON defined as 3000, and the flag_reset variable will reset the code properly after flash writing.
I am using the following:
nRF52832
SDK 12.2.0
Code based on experimental_ble_app_eddystone example.
Is there any solution to this, or maybe I am doing something wrong?
Thank you
