Can't restore Bonding
I have a problem at restoring the bonding that is saved on Android EEPROM. I'm using Nordic 8001
I'm using the example from proximity. I modified the services.h using NRFGO to support ANCS and i added 2 characteristic for talking with the iOS phone. At some point everything worked fine, but now i have a big problem at restoring the Bond. The restore bonding functions are the functions from proximity template, so i don't thing there is a problem at the code. I think there is a problem at the NRGO settings. What can cause problem at bonding process?
I attached the setup.xml file for NRFGO.
Thank you!
proximity_setup.xml
  • Looks like the Write Dynamic data failed with a CRC mismatch
    E3 :3, 84, 8, 88,
    Event : Length = 3 bytes (in decimal) Length = 0x03 (Hex) Event opcode = 0x84 (Hex) Command code for which this event is associated with = 0x08 (Write Dynamic Data) Status code = 0x88 = ACI Status Error CRC Mis match (See appendix in nRF8001 PS v1.2)
    = I can also see that the last message used in the Read Dynamic data is different from the last message in Write Dynamic Data
    Read Dynamic Data
    C1 :1, 7, E28 :1C, 84, 7, 2, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 14, 2, 91, 59,
    Write Dynamic Data
    C26 :1A, 8, 9, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 14, 2, 89, 1C, E3 :3, 84, 8, 88,
    As you can clearly see the last 2 bytes alone are different and this, I suspect , is the reason for the CRC failure.
  • Thank you! I changed some settings in NRFGo and now it works...
