Handling BLE_EVT_USER_MEM_RELEASE
As a central, I am writing to a variable length characteristic, advertised by a service of my peripheral. In this case, I am sending 80 bytes of 0x01 as a test
    uint8_t testData[80];
    size_t len = sizeof(testData);
    memset(&testData, 0x01, len);
    NSData *valData = [NSData dataWithBytes:&testData length:len];
    [self.peripheral writeValue:valData forCharacteristic:self.txCharacteristic type:CBCharacteristicWriteWithResponse];
image description
From a peripheral standpoint, I am relying on BLE_EVT_USER_MEM_REQUEST and replying with a statically allocated struct of type ble_user_mem_block_t. This block has enough memory to handle the write from the central. I then handle BLE_EVT_USER_MEM_RELEASE and attempt to dump the blocks p_mem buffer via NRF_LOG_HEXDUMP_DEBUG. This is where I'm stuck. The problem is, the contents of p_mem do not match what i was expecting, which is 80 bytes, set as 0x01. For example,
image description
In this post, it mentions a format of [HandleID 2 bytes] [Offset 2 bytes] [Length 2 bytes] [Data], but even then, the data isn't making sense to me, leading me to believe I've either misinterpreted the data, or I am logging in the wrong place. Can anyone steer me in the correct direction. My short term goal is to log the data that was written to this particular characteristic.
Here are the wireshark logs for reference.
Thanks!
Device: nRF52832 SDK: 13 Soft Device: S132
