Implement Static Passkey with SDK12.2.0
Hi, I want to use iOS to connect nRF82832 with passkey when connecting. I use pca10040_s132 with SDK 12.2.0.
Following is my procedure:
  1. define security parameters:
    #define SEC_PARAM_BOND 0 #define SEC_PARAM_MITM 1 #define SEC_PARAM_LESC 0 #define SEC_PARAM_KEYPRESS 0 #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY #define SEC_PARAM_OOB 0
  2. define passkey and set it:
// this is global variables
  #define STATIC_PASSKEY    "123456"
  static ble_opt_t    m_static_pin_option;
  uint8_t passkey[] = STATIC_PASSKEY;
// set passkey in gap_params_init()
    m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
    err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
  1. send pairing request and implemet pairing procedure
 // add those cases in on_ble_evt()
    case BLE_GAP_EVT_CONNECTED:
        ble_gap_sec_params_t params;
        params.bond = 0;
        params.mitm = 1;
        sd_ble_gap_authenticate(m_conn_handle,&params);
       // printf("receive pair request\n");
       // resp_pair_request();
       ble_gap_sec_params_t sec_params;
       uint32_t  err_code;
      sec_param.bond           = SEC_PARAM_BOND;
      sec_param.mitm           = SEC_PARAM_MITM;
      sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
      sec_param.oob            = SEC_PARAM_OOB;
      sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
      sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
      sec_param.kdist_own.enc  = 1;
      sec_param.kdist_own.id   = 1;
      sec_param.kdist_peer.enc = 1;
      sec_param.kdist_peer.id  = 1;
     err_code=sd_ble_gap_sec_params_reply(m_conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_param,NULL);
   case BLE_GAP_EVT_AUTH_STATUS:
          if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
            //printf("pair success\r\n");
               //  int s=0;
                // s++;
            sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
Conclusion: When I use iOS and start connect, the pairing message shows sucessfully and I then enter the passkey "123456". But it fails after senconds with alert:"Timeout interrogating the peripheral". Actually I find "printf("pair success\r\n");" arrives with debugging. So It should be connected. I donnot know why it comes this error. Is there something wrong with my configuration? Is peer_manager_init() important? I comment this function as I donnot need bond. Thanks a lot!
  • Hi longycy,
    I tried here with nRFMasterControl panel but don't see the same issue. When I turned off MITM ( turn off keyboard&display security option) to bond and then turn it on again after that, I simply have the passkey asking pop up and can continue normally. Here is the screenshot:
    image description
    Please make sure you deleted bond information on the RN4020 after the first trial.
    Do you have any Nordic board that you can use to test with nRFMaster Control Panel ?
    If possible, please record a sniffer trace when you test with RN4020. It can reveal why we have different result when testing with nRFMasterControlPanel vs RN4020.
    Also, please try to test with SDK v13.
  • Hi longycy,
    image description
