hello,will you please tell me which code i have to use in the sdk 12.2.0 for rf communication with nrf51822 and nrf24l01 .and also tell me which settings i have to do for nrf24l01 side as a transmitter.so that i can receive data on nrf51822 side.
Hi Pallavi
The ESB library in the nRF5 SDK v12.2.0 is designed to be backwards compatible with the nRF24L01/nRF24L01+, assuming you don't use the L01 device in legacy Shockburst mode (ACK's disabled).
On the nRF5 side you can use the esb_ptx and esb_prx examples as a starting point: \nRF5_SDK_12.2.0\examples\proprietary_rf\
For this to work you need the following settings on the nRF24L01 side:
Default address (0xE7E7E7E7E7), with 5 byte address length
16-bit CRC
2Mbps bitrate
Auto ACK and dynamic payload length enabled
For all other settings you can use the default values.
Edit: Added attachment.
Best regards
Torbjørn
hello sir, i have two nrf51 bords. but in one side i am using arduino with nrf24l01 and on the other side nrf51 board.then if you have the code please share.i am stuccked here badly.i want this communication for further implimentation of project on nrf51.
Thank you , Pallavi
Thank you , Pallavi
