i a have a problem debugging application with bootloader installed. I work with GCC for the application.
What is happening is the following: If i program application with DFU, and then lauch Eclipse debug it works. But if i do some changes in the code, rebuild and debug, the device goes into DFU, and i get an error in gdb
"No source available for 0x00".
If i flash new application with DFU i can debug again. If no bootloader installed everything works fine. I'm using SDK 13.
Is this a correct behaviour?
Thank you
