I use ESB sample code ,change to do 8k sample rate ADC(10bit) and transport by ESB ,but overflow when output receive data to PC use uart at UARTE_BAUDRATE_BAUDRATE_Baud1M. All my data is about 16KB/s,Is there somthing wrong ?
@Suker: I assume above is the result when you run my test ? At least at 460800 it's more than 20kB/s ? Please be aware that the example sending UART packet without using EasyDMA. I spot that it would take extra time between each byte. If you use EasyDMA you should achieve better through put.
