I use ESB sample code ,change to do 8k sample rate ADC(10bit) and transport by ESB ,but overflow when output receive data to PC use uart at UARTE_BAUDRATE_BAUDRATE_Baud1M. All my data is about 16KB/s,Is there somthing wrong ?
You can just simply replace NRF_SERIAL_MODE_IRQ with NRF_SERIAL_MODE_DMA in NRF_SERIAL_CONFIG_DEF then you will have DMA mode. You should try to increase the SERIAL_BUFF_TX_SIZE and SERIAL_FIFO_TX_SIZE, that would also help. I can achieve quite good result by increasing them, upto 966kbps with 1Mbps baud rate.
