i need to know the read and write time in (ms). for one page
please any ony help me
Isn't that in nRF51822 Product Specification (see NVIC chapter)?
Hi Satheesh,
you can find the specifications for the Non-Volatile Memory (FLASH) Controller in the nRF51822 Product Specification(Section 8.22), found here.
Best regards
Bjørn
In section 11.8.1 Flash Programming I have found the time to write one word. By I cannot find information about flash read operations, although this relevant when I need to calculate a CRC over a large flash data block or about a large code block. Do you have this information or do I need to start a measurement?
We do not have any spec for reading a word from flash, but reading a word directly using the address, should be very short, i.e. should only be a few instruction (few clock cycles needed), just to clock the data from flash to CPU's register and then to RAM via AHB bus. I don't think the NVMC module is involved here as it is only used when you write or erase flash. Reading from flash is just direct access from CPU to AHB.
I would suggest to toggle a pin when you do a read from flash (access the flash word directly with its address) and toggle it again after you finish, and use a logic analyzer to check the width pulse, i.e. the time it took to read the word from flash.
