Proximity Profile (Battery Measurement) not updating when SAADC LP mode Enabled
I am using SDK 12.2.0 with soft device s132 3.0.0 using NRF52 Development Board(PCA10040).
I want to update Battery level to central device/APP.As i want to use code for my custom Board i.e, battery operated ,so i want to configure in Low power mode.In 12.0.0 proximity example .there is an option to enable Low power mode.So,i Enabled.But it is not updating the Values.
#ifndef SAADC_CONFIG_LP_MODE
#define SAADC_CONFIG_LP_MODE 1
I am using the exact example problem,But it is not Updating the Values.
If i test the SAADC seperatly,There it is working.All code is similar Don't know how it is not working.
void SAADC_IRQHandler(void)
    if (nrf_saadc_event_check(NRF_SAADC_EVENT_END))
        nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
        NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_END));
				NRF_LOG_INFO(" SAADC in SAADC_IRQHandler  : Inside NRF_SAADC_EVENT_END \r\n");
        if (!m_cb.low_power_mode || m_cb.conversions_end)
            NRF_LOG_INFO(" SAADC in SAADC_IRQHandler  : Inside !m_cb.low_power_mode || m_cb.conversions_end. \r\n");
						nrf_drv_saadc_evt_t evt;
            evt.type               = NRF_DRV_SAADC_EVT_DONE;
            evt.data.done.p_buffer = (nrf_saadc_value_t *)m_cb.p_buffer;
            evt.data.done.size     = m_cb.buffer_size;
            if (m_cb.p_secondary_buffer == NULL)
                m_cb.adc_state = NRF_SAADC_STATE_IDLE;
                m_cb.p_buffer           = m_cb.p_secondary_buffer;
                m_cb.buffer_size        = m_cb.secondary_buffer_size;
                m_cb.p_secondary_buffer = NULL;
                if (!m_cb.low_power_mode)
                    nrf_saadc_task_trigger(NRF_SAADC_TASK_START);
										NRF_LOG_INFO(" SAADC in SAADC_IRQHandler  : Inside !m_cb.low_power_mode || m_cb.conversions_end. : Inside low power.\r\n");
            m_cb.event_handler(&evt);
            m_cb.conversions_end = false;
    if (m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED))
				NRF_LOG_INFO(" SAADC in SAADC_IRQHandler  : Inside m_cb.low_power_mode && nrf_saadc_event_check(NRF_SAADC_EVENT_STARTED)\r\n");
        nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
        NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STARTED));
        if (m_cb.buffer_size_left == 0)
            // Sampling finished, next buffer in progress.
            m_cb.buffer_size_left = m_cb.buffer_size - m_cb.active_channels;
            nrf_saadc_buffer_init((nrf_saadc_value_t *)&m_cb.p_buffer[m_cb.buffer_size -
        m_cb.buffer_size_left],
                                  m_cb.active_channels);
        else if (m_cb.buffer_size_left > m_cb.active_channels)
            // More samples to convert than for single event.
            m_cb.buffer_size_left -= m_cb.active_channels;
        else if ((m_cb.buffer_size_left == m_cb.active_channels) &&
                 (m_cb.p_secondary_buffer != NULL))
            // Samples to convert for one event, prepare next buffer.
            m_cb.conversions_end  = true;
            m_cb.buffer_size_left = 0;
            nrf_saadc_buffer_init((nrf_saadc_value_t *)m_cb.p_secondary_buffer,
        else if (m_cb.buffer_size_left == m_cb.active_channels)
            // Samples to convert for one event, but no second buffer.
        nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE);
    if (nrf_saadc_event_check(NRF_SAADC_EVENT_CALIBRATEDONE))
        nrf_saadc_event_clear(NRF_SAADC_EVENT_CALIBRATEDONE);
        NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_CALIBRATEDONE));
        evt.type = NRF_DRV_SAADC_EVT_CALIBRATEDONE;
    if (nrf_saadc_event_check(NRF_SAADC_EVENT_STOPPED))
        nrf_saadc_event_clear(NRF_SAADC_EVENT_STOPPED);
        NRF_LOG_DEBUG("Event: %s.\r\n", (uint32_t)EVT_TO_STR(NRF_SAADC_EVENT_STOPPED));
        uint32_t          limit_flags = m_cb.limits_enabled_flags;
        uint32_t          flag_idx;
        nrf_saadc_event_t event;
        while (limit_flags)
            flag_idx     = __CLZ(limit_flags);
            limit_flags &= ~((1UL << 31) >> flag_idx);
            event        = FLAG_IDX_TO_EVENT(flag_idx);
            if (nrf_saadc_event_check(event))
                nrf_saadc_event_clear(event);
                evt.type                  = NRF_DRV_SAADC_EVT_LIMIT;
                evt.data.limit.channel    = LIMIT_EVENT_TO_CHANNEL(event);
                evt.data.limit.limit_type = LIMIT_EVENT_TO_LIMIT_TYPE(event);
                NRF_LOG_DEBUG("Event limit, channel: %d, limit type: %s.\r\n", evt.data.limit.channel, (uint32_t)EVT_TO_STR(evt.data.limit.limit_type));
It is Entering into the above function.From this it is not calling the below function.(Where as when SAADC LP mode disabled ,it is calling the below Function.)
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
		NRF_LOG_INFO("Entered into SAADC event Handler.\r\n");
				NRF_LOG_INFO("Entered into SAADC event Done.\r\n");
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
				NRF_LOG_INFO("Loaded Buffer into adc result.\r\n");
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
				NRF_LOG_INFO("Coverting data Buffer as Read.\r\n");
				NRF_LOG_INFO("The adc Value : %d. \r\n",adc_result);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl);
        if (
            (err_code != NRF_SUCCESS)
            (err_code != NRF_ERROR_INVALID_STATE)
            (err_code != BLE_ERROR_NO_TX_PACKETS)
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
Please, Help out if any one aware of it.
