Example Serial Secure DFU Bootloader not work
I used a PCA10040 dev kit with nrf52832 to test Serial Secure DFU Bootloader.
Followed all the steps in the example with my PC (Ubuntu 16.04.1 LTS 64-bit).
I used the images that are in the folder \examples\dfu\ble_dfu_send_hex
  1. Erase Dev Kit
    • nrfjprog -e -f nrf52
  2. Flash Soft Device
    • nrfjprog --program .../nRF5_SDK_13.0.0_04a0bfd/components/softdevice/s132/hex/s132_nrf52_4.0.2_softdevice.hex -f nrf52 --sectorerase
  3. Install micro-ecc
  4. Compile and program the bootloader - cd .../nRF5_SDK_13.0.0_04a0bfd/examples/dfu/experimental_bootloader_secure_serial/pca10040_debug/s132/armgcc
  • make clean && make
  • nrfjprog --reset --program _build/nrf52832_xxaa_s132.hex
  1. The board entered in dfu mode was left with the leds 1 and 3 lit
  2. Installed nrfutil (tried with installed from PyPI and from source)
  3. Run nrfutil dfu serial -pkg dfu_test_app_hrm_s132.zip -p /dev/ttyACM0 -b 115200
  4. I got the following output:
From PC:
 [------------------------------------]    0%
  File "/usr/local/bin/nrfutil", line 11, in <module>
    load_entry_point('nrfutil==2.3.0', 'console_scripts', 'nrfutil')()
  File "/.local/lib/python2.7/site-packages/click/core.py", line 722, in __call__
    return self.main(*args, **kwargs)
  File "/.local/lib/python2.7/site-packages/click/core.py", line 697, in main
    rv = self.invoke(ctx)
  File "/.local/lib/python2.7/site-packages/click/core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/.local/lib/python2.7/site-packages/click/core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/.local/lib/python2.7/site-packages/click/core.py", line 535, in invoke
    return callback(*args, **kwargs)
  File "/usr/local/lib/python2.7/dist-packages/nrfutil-2.3.0-py2.7.egg/nordicsemi/__main__.py", line 605, in serial
    dfu.dfu_send_images()
  File "/usr/local/lib/python2.7/dist-packages/nrfutil-2.3.0-py2.7.egg/nordicsemi/dfu/dfu.py", line 118, in dfu_send_images
    self._dfu_send_image(self.manifest.bootloader)
  File "/usr/local/lib/python2.7/dist-packages/nrfutil-2.3.0-py2.7.egg/nordicsemi/dfu/dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.send_init_packet(data)
  File "/usr/local/lib/python2.7/dist-packages/nrfutil-2.3.0-py2.7.egg/nordicsemi/dfu/dfu_transport_serial.py", line 245, in send_init_packet
    raise NordicSemiException("Failed to send init packet")
pc_ble_driver_py.exceptions.NordicSemiException: Failed to send init packet
--------------------------------------------OR------------------------------------------------
    sys.exit(cli())
  File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 722, in __call__
  File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 697, in main
  File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 1066, in invoke
  File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 895, in invoke
  File "/usr/local/lib/python2.7/dist-packages/click/core.py", line 535, in invoke
  File "/usr/local/lib/python2.7/dist-packages/nordicsemi/__main__.py", line 605, in serial
  File "/usr/local/lib/python2.7/dist-packages/nordicsemi/dfu/dfu.py", line 118, in dfu_send_images
  File "/usr/local/lib/python2.7/dist-packages/nordicsemi/dfu/dfu.py", line 83, in _dfu_send_image
    self.dfu_transport.open()
  File "/usr/local/lib/python2.7/dist-packages/nordicsemi/dfu/dfu_transport_serial.py", line 190, in open
    if self.__ping() == False:
  File "/usr/local/lib/python2.7/dist-packages/nordicsemi/dfu/dfu_transport_serial.py", line 321, in __ping
    + 'Expected: 0x{:02X} Received: 0x{:02X}'.format(operation, resp[1]))
NameError: global name 'operation' is not defined
From Board:
:INFO:Inside main
:DEBUG:In nrf_bootloader_init
:DEBUG:In real nrf_dfu_init
:DEBUG:running nrf_dfu_settings_init
:DEBUG:Enter nrf_dfu_continue
:ERROR:Single: Invalid bank
:DEBUG:Application sent bootloader request
:DEBUG:In nrf_dfu_transports_init
:DEBUG:num transports: 1
:DEBUG:UART initialized
:DEBUG:After nrf_dfu_transports_init
:DEBUG:Waiting for events
:WARNING:Received unsupported OP code
:DEBUG:Sending Response: [0x9, 0x3]
I tried with bootloader and softdevice images and the result was the same
I tried to decrease baudrate and disable flow control as recommended in post: devzone.nordicsemi.com/.../
As I saw this post I also tried a VM with Ubuntu 16.04 and obtained the same results
The example BLE Secure DFU Bootloader worked well and I successfully amanged to update the application and softdevice.
Does anyone have an idea how to solve this problem or have some idea that can help ?
