Undefined symbol nrf_drv_twi_init (referred from main.o).
Hello, I am using pca10028 and sdk12.2. I am trying to take sensor reading via TWI and I want to send this reading over ble. So I am trying to add twi files in ble_app_template project. After adding TWI file I am getting error such as :
L6218E: Undefined symbol nrf_drv_twi_enable (referred from main.o). L6218E: Undefined symbol nrf_drv_twi_init (referred from main.o).
I have enabled #define TWI1_ENABLED 1 and #define TWI0_ENABLED 1 from sdk_config.h app. I have also included paths like: components\drivers_nrf\twi_master
My code is attached below:
main.c
New Text Document.txt
Thanks, Shailav
  • Hello shailav619
    I have looked at your code. You can remove the line
    #include "nrf_drv_twi.c"
    As it is not necessary.
    Instead you need to add the nrf_drv_twi.c file to the project. You can find this file in the directory located at [SDK-Folder]/components/drivers_nrf/twi_master
    If you are using Keil simply double click on the nRF_drivers folder in the left hand side folder-tree, and add the file through the window that opens.
    Next go into sdk_config.h, and click on the configuration wizard tab. Here check the box next to TWI_ENABLED, and inside the TWI_ENABLED tree check the box next to TWI0_ENABLED.
    If you're not using Keil you will need to make the corresponding changes in the sdk_config.h file manually by setting the TWI_ENABLED and TWI0_ENABLED to 1.
    Best regards
    Jørn Frøysa
  • Thanks Jørn Frøysa. It worked :)
