Saving words in FDS memory ?
I was able to use the fds with the help of good people here , I am trying now to save a word into memory.
As I see in the docs, the only way to save data is by uint32_t chunks .
So I guess I am doing it wrong but I am trying this without success :
to save with this :
        char data[]="lola";
        uint32_t save;
        memcpy(&save, data, 4);
        #define FILE_ID     0x1111
	#define REC_KEY     0x2222
	fds_record_t        record;
	fds_record_desc_t   record_desc;
	fds_record_chunk_t  record_chunk;
	// Set up data.
	record_chunk.p_data         = &save;
       record_chunk.length_words   = 1;
	// Set up record.
	record.file_id              = FILE_ID;
	record.key              		= REC_KEY;
	record.data.p_chunks       = &record_chunk;
	record.data.num_chunks   = 1;
Then to read with :
... //some code that works , then
			 data = (uint32_t *) flash_record.p_data;
			for (uint8_t i=0;i<flash_record.p_header->tl.length_words;i++)
                                   char bytes[6];
                                   char n =  data[i];
                                   bytes[0] = (n >> 24) & 0xFF;
                                   bytes[1] = (n >> 16) & 0xFF;
                                   bytes[2] = (n >> 8) & 0xFF;
                                   bytes[3] = n & 0xFF;
                                   for (int k=0;k<4;k++)
                                       NRF_LOG_INFO("message is: %c ",bytes[k]);
				//NRF_LOG_INFO("record ID: %d and data: %x ",record_desc.record_id,data[i]);
Which will print record 1 and data - means empty data
  1. Is this the way to save a word ?
  2. what about saving multiple words like this ? is it a overhead ?
Thanks !
  • FormerMember
    0 FormerMember
    The below code shows how to store and retrieve a string using FDS:
    static ret_code_t fds_test_write(void)
    	static char const my_text[]    = "What a day, what a day!";
    	// Set up data.
    	record_chunk.p_data         =  my_text;
    	record_chunk.length_words   =  (sizeof(my_text)+3)/4;  // When calculating the length in words, using integer division, the result will always be "rounded" down to the whole integer. A data array of 21 bytes, is strictly speaking 5 words + 1 byte. However, the length should be in words, and thus 6 words are needed to store all the data. 21/4 = 5, (21+3)/4 = 6. For 20 bytes, 5 words are needed, in integer division 20/4 = (20+3)/4 =5.
    	// Set up record.
    	ret_code_t ret = fds_record_write(&record_desc, &record);
    	if (ret != FDS_SUCCESS)
    			return ret;
    	 NRF_LOG_INFO("Writing Record ID = %d \r\n",record_desc.record_id);
    	return NRF_SUCCESS;
    static ret_code_t fds_read(void)
    	fds_flash_record_t  flash_record;
    	fds_find_token_t    ftok ={0};//Important, make sure you zero init the ftok token
    	char     *p_data;
    	uint32_t err_code;
    	NRF_LOG_INFO("Start searching... \r\n");
    	// Loop until all records with the given key and file ID have been found.
    	while (fds_record_find(FILE_ID, REC_KEY, &record_desc, &ftok) == FDS_SUCCESS)
    			err_code = fds_record_open(&record_desc, &flash_record);
    			if ( err_code != FDS_SUCCESS)
    				return err_code;
    			NRF_LOG_INFO("Found Record ID = %d\r\n",record_desc.record_id);
    			NRF_LOG_INFO("Data = ");
    			// Access the record through the flash_record structure.
    			p_data = (char *) flash_record.p_data;
    			NRF_LOG_INFO(" %s \r\n", (uint32_t)p_data);
    			// Close the record when done.
    			err_code = fds_record_close(&record_desc);
    			if (err_code != FDS_SUCCESS)
    				return err_code;
    	return NRF_SUCCESS;
