gazell out_of_sync and in_sync
hi ,all
I feel confused about" out_of_sync" and" in_sync" parameters .If a devece is in sync,how the channels was changed ?And what's the use of"nrf_gzll_set_device_channel_selection_policy())"? And how could I get the sync_lifetime in our softcode ?
  • Hi Anna
    In Gazell the host is continuously cycling through the channel table at a fixed rate, regardless of what the devices are doing.
    A device being out of sync simply means that the device don't know what channel the host is currently on, and it will then have to retransmit the packet on the same channel while waiting for the host to respond. As soon as the device gets an ACK from the host it know what channel the host is on, and it will then switch to in_sync mode. Once the device is in sync it can immediately send new packets on the correct channel of the host, reducing the number of retransmits needed.
    If you are in sync but don't send any data for a long time you might drop out of sync, because the timers in the device and host don't run at exactly the same speed.
    The nrf_gzll_set_device_channel_selection_policy() function is documented here.
    To get the sync_lifetime you can use the nrf_gzll_get_sync_lifetime(void) function.
    Best regards
    Torbjørn
  • Hi
    If you want the device to stick to the same channel over and over you should use the NRF_GZLL_DEVICE_CHANNEL_SELECTION_POLICY_USE_SUCCESSFUL channel selection policy. Then the same channel will be used as long as the packet loss on that channel is not too high.
    The method you describe, where the host is configured with multiple channels and the devices with a unique sub set, is the recommended way to reduce interference when you have multiple devices. Just remember to set the timeslot period 4 times as long on the device side, and make sure that the device channels are 'interleaved' in the host.
    In other words, in the host the channels should be configured like this:
    Dev 1 ch 1, dev 2 ch 1, dev 3 ch 1, dev 4 ch 1, dev 1 ch 2, dev 2 ch 2 ++++
    If no ACK is received on a certain channel the device will pick the next channel in the list and try again.
    Best
  • Hi
    Best
